How To: Headunit firmware & GPS navigation maps update
Anyone saw changes with displayed speed limits ? Like in: correctly read / recognized and from map data ? Neither works on a brand new i20N Performance, we just bought (sw and map data from summer 2023): also: petrol station POI display in map doesn't work. Has somebody seen these re-appear after the software update ?
The speed limit issue has now ben fixed in the latest update. Petrol station POIs are also ok.
I installed the update and noticed MUCH better behaviour with speed limits (needs more verification over time). I don't see the petrol staizons, displayed on the map (like super markets, museums, etc.). Maybe I need to wait for a deeper "reset" of the car. I also haven't noticed the "automatic vent close in tunnels", but I HAVE noted the expanded menu in the map, where you can directly locate POI's (including petrol stations, btw... ;) )
Hi all, I recently got the sw upgrade for my pre-facelift Fastback - the one with the ugly generic car graphics.
What I notice is that on startup of the car, scanning the USB drive for music seems to take quite a lot longer than before (I have relatively a lot of music on the USB drive). Anyone noticed that?
Just want to come back to this problem - turns out it was the USB stick. Seems over time it developed a few bad sectors, as I could not read all files from the stick, and even on a Mac, reading the folders took a long time. Guess USB drives really do wear out faster on the blocks where the folder structure is stored.
Anyway, a full reformat of the stick sorted it out.
Reactions: Jajodu
When I use the Hyundai update service/website it automatically reformats the drive before downloading the new software.
update: promised “gas stations on map” features did not appear after waiting, with one exception: Esso is on the map. Meanwhile updated second i20 (my daughter’s car). Same behavior.
Do you have "Auto-display filling stations when fuel level is low" selected? If so, deselect.
I am almost sure I have it selected. cant wait to check (when the new day has dawned). Will keep you updated…
Muss ich eigentlich nur die am PC vorbereiteten Daten auf den Datenträger laden und diesen dann beim Fahrzeug an die USB Ladebuchsen hängen ?
Bin immer noch am laden der Daten auf eine portable USB-HD. Gehe nachher hoch in die Garage und hänge die Disk an den USB Anschluss. Wenn es mir die ECU zerbläst, Pech gehabt
Die Chancen sind ganz gut, dass das nicht passiert. Wichtig: für ausreichend Batteriekapazität sorgen. Ich habe bisher zwei Updates gemacht, und bin dabei einfach je eine Dreiviertelstunde gefahren.
