Front Camber Options for PFL i30N Hatchback?
TheNewOneHere
2
Macau
Hi everyone,
I have a 2020 (PFL) i30N Hatchback and need more front camber for track days to stop wearing out my tire shoulders.
Since this is still a street car, I want to avoid the harsh metal clunking and NVH of racing camber plates. I also do not want to use camber bolts due to reliability and slippage concerns under heavy track loads.
  1. Can I directly retrofit the Facelift (FL) front control arms to get more camber? Are they a direct bolt-on swap for the PFL Hatchback?
  2. Are there any other recommended setups (like offset bushings) that provide a good balance between track performance and street comfort?
Thanks for any advice!
1. The FL front control arms will not give you more camber
2. Have a look at the bushings from powerflex, they offer offset ones.
By the way, camber bolts cannot be used on the i30N ;)
Only options for more camber are different strut tops or offset bushings
