muaDib
Romania
Hyundai i30 N Performance Exhaust Valve Issue​
I have a 2019 Hyundai i30 N Performance Fastback and I’d really appreciate your help, as I’m not sure what else I should check.
On the 25th of last month, I replaced the exhaust valve spring because it had become weak and the valve was making a rattling noise. I installed an upgraded spring, and everything seemed to be fine after the replacement.
Now I’m experiencing the following symptoms:
  • Engine off: the exhaust valve remains open.
  • When starting the car: the valve performs its self-test.
  • Engine running: the valve remains partially open.
  • If I switch the driving mode from Normal to N / N Custom, or vice versa, the valve doesn’t move at all (it doesn’t open or close).
  • I also reset the car by disconnecting both the positive (+) and negative (-) battery terminals for 25 minutes. After that, it doesn’t make any pops at all anymore.
What could be causing this issue? Has anyone experienced something similar?
What else should I check, or what tests could I perform to identify the problem?
Any suggestions or similar experiences would be greatly appreciated. Thank you!
it could be that your valve itself is just a bit stuck and needs some movement. I have a Invidia q300 cat-back system. And for me it was stuck on the open position for a while, I ended up using a flathead screwdriver and moving the valve from open to closed a couple of times until it moved "free".
Worked for me. Let me know if it helps!
