Brakes "Check brake pad wear before track driving"
Jacko315
9
2
United Kingdom
Hi all, I just recently bought my i20 N, its got 51k miles on. Every time I put the car into N mode, the warning in the title appears. From what I have researched it seems to be a faulty sensor? From the cars last service I can see the brake pads were measured at 9mm. How low should they be before the warning starts appearing, and what are my options to stop it from happening? Thanks all.
Not my picture, just an example from Google Images:
Got the warning with 5mm left all 4 pads at front were cracked.
There already was some sensor to disc wear. Maybe the pre owner did change the pads and has left the destroyed sensor on yours.
You can eliminate that shit, by undoing the sensor and making a circuit bridge to the connector.
Reactions: Jacko315
Thanks, guess I will have to do the workaround, thanks.
I have the same issue. Even went to a track with the warning, having inspected the brake pad myself. Would like to have it fixed though.
Would you replace the sensor or just bridge the connectors to "fix" it? I have found a replacement sensor online for 12 euro, but only the front one
Probably replace in case I want to sell it later with good conscience.
Sounds pretty cheap. Do you have a link? And do you know where the sensor is located? 😅
This seems to be the one, not sure:
From what I can see the wire is located behind the brakes, mines obvious on the front at least, can see a cable sticking out at the top behind the brake disc
Thanks. Will have a look myself and come back to you. Always sucks when threads are left open without any solution or conclusion 😄
Yeah, thought I would ask again. There are a few of these exact threads floating round here, on other forums and even facebook, but there is never a real fix, more of a "do this to make it go away".
However, I would try cleaning yours first, apparently dirt in the sensor can give false readings?
The fix is to reassemble that sensor, because it will also melt away. Or to reassemble it many kilometres before it gets destroyed.
I cut off the connector, opened it, repined one pin, made a circuit bridge and put the pin back.
Then I connected the bridged connector to the connector that comes from the wiring loom, to protect it from oxidation & dirt.
Reactions: YNWaN and Jacko315
Cheers, I'll give that a go
Mine has aftermarket calipers and so also has aftermarket pads. These pads don’t have a wear sensor - you can get ones with an electrical wear sensor but it’s a different type! Anyway, you can just remove the wheel and look at where the wear sensor cable is plugged into the cars wiring (it’s a short wiring tail from the brake pad to the car) - cut the sensor wire and solder the two wires together (or crimp them). You won’t have a wear sensor anymore but you also won’t have any error messages.
The i20N sensor is a two stage type. When the first bit is triggered it gives the warning you have - partially worn.
if You don’t want to rebuild anything you can just buy the sensor cable which plugs into the car and the pad. On some cars the cable is physically part of the pad but not on these.
Reactions: Jacko315
if You don’t want to rebuild anything you can just buy the sensor cable which plugs into the car and the pad. On some cars the cable is physically pard of the pad but not on these.
Thank you for the detailed explanation
Side note, that stage 3 on your car must be absolutely insane, surely 300HP in a FWD is pushing the limit 😆
You’re welcome 👍.
Yes, grip is the limitation, at least when pulling away ‘enthusiastically’ anyway 😁.
  • Haha
Reactions: Jacko315
Back. Great replies with guidance everyone!
Anyway, I havent had the chance to unmount my my wheels so I find it difficult to locate the sensor.
@Jacko315 Please do report back if you get things working. Will do that same but currently have limited time and live in an apartment, making it hard to fiddle with the car :/
Reactions: Jacko315
