Brakes "Check brake pad wear before track driving"
Jacko315
7
United Kingdom
Hi all, I just recently bought my i20 N, its got 51k miles on. Every time I put the car into N mode, the warning in the title appears. From what I have researched it seems to be a faulty sensor? From the cars last service I can see the brake pads were measured at 9mm. How low should they be before the warning starts appearing, and what are my options to stop it from happening? Thanks all.
Not my picture, just an example from Google Images:
Got the warning with 5mm left all 4 pads at front were cracked.
There already was some sensor to disc wear. Maybe the pre owner did change the pads and has left the destroyed sensor on yours.
You can eliminate that shit, by undoing the sensor and making a circuit bridge to the connector.
Reactions: Jacko315
Thanks, guess I will have to do the workaround, thanks.
Would you replace the sensor or just bridge the connectors to "fix" it? I have found a replacement sensor online for 12 euro, but only the front one
Probably replace in case I want to sell it later with good conscience.
Sounds pretty cheap. Do you have a link? And do you know where the sensor is located? šŸ˜…
This seems to be the one, not sure:
From what I can see the wire is located behind the brakes, mines obvious on the front at least, can see a cable sticking out at the top behind the brake disc
Thanks. Will have a look myself and come back to you. Always sucks when threads are left open without any solution or conclusion šŸ˜„
Yeah, thought I would ask again. There are a few of these exact threads floating round here, on other forums and even facebook, but there is never a real fix, more of a "do this to make it go away".
However, I would try cleaning yours first, apparently dirt in the sensor can give false readings?
The fix is to reassemble that sensor, because it will also melt away. Or to reassemble it many kilometres before it gets destroyed.
I cut off the connector, opened it, repined one pin, made a circuit bridge and put the pin back.
Then I connected the bridged connector to the connector that comes from the wiring loom, to protect it from oxidation & dirt.
Reactions: Jacko315
Cheers, I'll give that a go
