It seems as though the BOV/recirc valve is actuated by a solenoid that controls the vacuum supply from the intake manifold as opposed to the conventional method of just having it hooked up to a vacuum line on the intake manifold directly. Not sure what the reason is, but it seems to only keep the valve open for a very short period of time after the throttle is released, and then closes it again even though there's still pressure in the charge pipes/IC system. If you have an intake, you can hear compressor surge as a result after the BOV/recirc valve closes during this scenario.
It definitely makes for some odd sounding BOV actuations...
