Brakes Bigger brake kit?
Ha, again, that’s exactly what I’ve ordered 😁🤙, same size and ET! Can’t wait for them to arrive 🥰. Not the cheapest option, but nice.
Have you measured up for the wheels?
The brembos are pretty thick calipers like, iv ended up on a 18x8 et40 with my front wheels to get the caliper clearance
Reactions: RossTi30N
Yeah, that’s why I’ve gone for the OZ, the back of the spokes have better clearance than many others.
Yea i did have a brief look at at them, well a few oz wheels actually, but just went with the bolas in a et40 on the front as they are miles cheaper and they are lighter. Plus i needed 2 sets for a set of track wheels also
Reactions: YNWaN
Had my OZ ultraleggera fitted today and weighed them - 8.5 kg (8 x 18).
I have the BBK by machined performance, I think I have the same caliper ( brembo megane 3 rs ) and I don't want a spacer, with Bola FLE 8X18 ET 40 you don't have any problem? Do you have some picture of rims please?
For your brake disc, where can I buy this model?
Yea et40 on the bola fle 18x8 fit fine. To be honest i think alot of wheels in an et40 would fit.
My discs are from godspeed they are 355mm though not the standard size that the machined performance kit uses
thank you for your answer
I received the BOLA FLE 8x18 ET40 the rim rubs on the caliper I added a 3mm shim and it's the same thing. @YNWaN the OZ rims are ET48? the BOLA are 20mm out of the fender, it's horrible.
Somethings not right there. I run 18x8 et40 bola fle on the front of my car with brembo 4 pots and i have aprox 3mm clearance to the caliper. And they certainly dont stick out that far but i have abit of camber dialed in
Thank you for this picture
Hi there, yes my OZ are ET48 and with a 3mm spacer on the front they just clear the calipers. The tyres are pretty much flush with fenders though and the wheels, on their own fit inside the fenders.
