Hi,
as far as i know, you have to connect the new battery then switch ignition on for about 30 sec. (not start the engine), switch off, close all doors, lock the car and leave it alone for at least 4 hours, then the ECU resets the learned battery values and start new learning cycle.
They did scan the battery to ascertain that it was still fit and able to hold charge - no mention of the ECU though.it sounds like the RAC should be connecting a scan tool and telling the ECU that the battery has been replaced
Thanks! According to CTEK their CT5 START/STOP charger is suitable for all types of 12V lead-acid batteries (WET, MF, Ca/Ca and GEL) and is even optimized for AGM and EFB-batteries. Max output is 14.55 V, 3.8 A and it doesn't provide harsher voltage peaks during reconditioning phases like many others. I guess that would be fine?I am pretty sure it is an EFB battery.
EFB are also used for start/stop function, they could only charged with up to 14,3-14,4V max.
The regulator of the alternator pushes out 14,3-14,4V, checked with multimeter.
I use a CTEK MXS 5.0Thanks! According to CTEK their CT5 START/STOP charger is suitable for all types of 12V lead-acid batteries (WET, MF, Ca/Ca and GEL) and is even optimized for AGM and EFB-batteries. Max output is 14.55 V, 3.8 A and it doesn't provide harsher voltage peaks during reconditioning phases like many others. I guess that would be fine?
Ok thanks! Apparently the i20 N battery is EFB. According to CTEK that'll work, but it might be better to not use any 15v recond modes etc.I use a CTEK MXS 5.0
Found myself last weekend with a flat battery after a parking on the sun on a really hot summer day. It was weird because a day earlier the start&stop worked well and I do extensive mileage every week with the car (about 300-400km weekly). The original battery was an CMF60L-DIN, the car is from September 2023. The replacement fitted by the dealer, to my surprise, is an AGM, with reference LP370APE060SH1
One problem I can see with the Varta D39 looks to be that the positive and negative terminals are swapped over side to side compared to the standard battery. As the battery leads are very short I think you may struggle to connect the Varta up as the terminals will be a bit further forward in the engine bay.Hi,
My battery is dead, looking for replacing it my self, looking at Varta D39, but I am not sure which bolts are the ones holding the battery, could anyone show me a pic which bolts to loose and do you also think that the battery (Varta D39) is suitable?
Yes, faced that issue, going now to try a Varta A8, lets see if it will work this timeOne problem I can see with the Varta D39 looks to be that the positive and negative terminals are swapped over side to side compared to the standard battery. As the battery leads are very short I think you may struggle to connect the Varta up as the terminals will be a bit further forward in the engine bay.
