^Well, sort of. The ECM manages load based on various torque limiters, as well as limits output based on fluid (including air) temperatures and barometric pressure (approximates elevation) measurements.
There are base maps and optimum maps for certain variables (mainly load and timing). If limiter thresholds aren’t crossed and fluid temperatures don’t induce output reductions, the ECM will attempt to achieve optimum values.
The MAP sensor, located on top of the IM is what measures IATs. So, while higher IATs pre-compressor do negatively affect compressor efficiency slightly, the air still has to go all the way through the charge system (including intercooler) before the IAT is even measured by the MAP sensor probe, inside the IM.
