ADP low speed unlock box/ Ioniq guy.
ac/dc n 5
96
25
Morris, Illinois
Hi all. Just got the newly restocked ADP unlock box. I am going to install it when I have time to also do the Musway amp since they are in the same neighborhood. Looks like kinda a PITA to install. The passenger rear seat and a couple seatbelts need to be removed to get to the amp anf ADP box. Doable for some/most, but the idea of "plug and play" also means removing half the rear seat and a couple of the seatbelts. Just sayin.............
Did the install earlier this week. The online video instructions for both pieces cover just about everything you need to know/do. A couple things; I got caught up when first testing the breakout box. When I hooked the battery back up and turned on the car, NO ACTIVE SOUND AT ALL!!!!!! Oh no WTF did I just do? Had to bail to inside and check the interwebs. Somehow in clicking around I (re) discovered that the sounds do not work in ECO or Normal modes. When the battery was reconnected, the thing booted up in NORMAL mode.....no sounds. Switched to SPORT and everything is cool. Just thought that might HBO. Also, not that the Musway is installed, the sorry rear sub is showing its price point. Mission creep, anyone?
A few things on that:-
1). I'm sure I saw on the YouTube review of this is that the latest version of this ADP unlock box does work on all drive modes so you should get maximum sound in Eco, Normal and Sport as well as N mode if N-Active Sound is activated on all modes.
2). This ADP unlock box is currently only compatible with North American spec cars. As far as I have read, it hasn't to date been tested on European spec cars... so anyone in the UK for example wanting to spend £500 getting one of those in... there is a good chance it won't work on your 5N.
3). It's definitely NOT compatible with the 6N.
Hi.
On my car, ADP is not available to activate in eco or normal in the Hyundai setup menu. Never did, and still does not have, sound in eco or normal.
On my 5N (2025 UK spec), I can have N-Active Sound on all drive modes. It's a little quieter in Normal and Sport mode than it is in N mode (set to maximum volume) and it's quieter still in Eco but you can still hear it. I would've thought this was the case in all 5N models... maybe not for the North American spec cars...?
Any reason why it wouldn’t work on RHD cars? Surely the wiring couldn’t be that much different.
It took a while but I may have figured something out. Kinda. Since I first installed the box, it seemed like sometimes it would work and sometimes not. I don't use the sound all the time, and the seemingly random nature of working/not working took a while to notice a pattern. I drive mostly in sport mode, and only use N mode when I.......neeed it. What I have discovered is if I am in sport and turn the sound on it works. Then I can go to N and it stays on. If I go into N first, the sound will not come on at all. I have to go back to sport, turn the sound on, then back to N.
BTW, the startup and shutdown chimes are like almost annoyingly loud now, and there does not seem to be any way to turn them down or off that I can find.
