Check out the thread here, it's all about Spacesavers/Spares ...Any idea if a space-saver will fit under the boot floor, at fist glance it looks like it might?
Snap, although we do get one very intermittent bus service but no pub, shop, street lighting and the road sweeper refuses to process our road because it is un-adopted - funny we pay the same Council Tax as everyone else though!living without a vehicle in a village with no trains or buses
if you suffer from back pain, the KonaN may not be a good choice, because the suspension is rather firm. I suppose it all depends on the state of the roads in your country.Hi all
I am teetering on the edge of a purchasing a brand new Kona-N but without having any chance of a test-drive, I would just like to sit in one to confirm the seat is OK from my creaky old back.
It would appear the N comes with an electric adjustable lumbar support but could someone confirm that it has a 4-way adjustment, i.e. does it go "up & down" as well as "in & out" ??
Thanks in advance
On my Hyundai kit it was the normal large plastic disc with a bolt coming out the middle - probably better to fix it down as you don't want a heavy wheel bouncing around inside the car in the event of any mishaps!So does anything clamp the wheel in place or does it just stay put ok? I carry loads of junk in the boot so the space instead of the foam will be useful.
There is a threaded (m8) hole in the floor into which the threaded bar goes, the cap then winds down the shaft until tight against the wheel. I had to add some PTFE tape to the threaded bar on the item I got from ebay as it didn't feel as 'secure' in the hole as I wanted (it must be a thou or so off of the correct M8 size). I also added my own rubber gasket between the cap and the surface of the wheel as I didn't want any scuffing..I assume there is something on the floor that a bolt will screw into to fix the wheel down?
Yes it is the same outfit - the wheels & tyres seem OK(ish) but I would steer clear of the jack & tools.maybe the company you mention or a spin-off of it but I don't need the tools.
You could be correct - Now I'll have to go check which bolt I used to test itI thought mine was M10 but might be confusing it with my Mazda one I have been trying to sort?
Oooer - you did say you had to pack it with PTFE - was it that thick stuff for gas joints? Maybe thick enough to make M8 bolt tight in M10 receptacle?You could be correct - Now I'll have to go check which bolt I used to test it![]()
The more difficult bit to accomplish is a large enough washer to clamp the wheel down with?Don't worry guys, I have 8mm & 10mm threaded bar in the garage, just glad it sounds easy enough to do.
Nah, not that much! Just a couple of turns to make it 'toight like a toiger' (to quote Goldmember) ..Oooer - you did say you had to pack it with PTFE - was it that thick stuff for gas joints? Maybe thick enough to make M8 bolt tight in M10 receptacle?
I used some thick rubber insulating mat and cut a disc out of it.The more difficult bit to accomplish is a large enough washer to clamp the wheel down with?
