The last set on eBay appear to have sold for £1K but I would likely accept £800. The tyres aren’t fitted so that’s not a problem.
Thank you, and yes i have been watching a lot of tyre reviews videos and i have come to realize you should not be cheaping out on tyres, so i have been looking at Michelin PS5 and Continental WinterContact for winter tyre.Wheel/Rim size is fine but be sure to check if they might rub. Are you comparing like quality tires or cheapo (brand or type)
thank you for the answer, i will look around moreUntil you fit and try you don't but for the difference you are talking about it should be fine, assuming you didn't do other changes like e. g. lowered the car.
The new tire will be 5mm wider on either side and about 6mm "taller" than the original, nothing to be worried about. When new it will cause your speedometer to show slightly less speed than you are actually going but again, nothing to be worried about since all speedometers shows a bit higher speed than the actual.
I'm sure if you search more in the forum , you will find posts and people who already did this switch.
Quick tyre question,if anyone can advise.
will 225 fit ok on i20n
Anyone know why they are so much cheaper than 215?
Just to let you know that officially you can only use the following tyres and rims in Slovenia:So i am a bit of a noob when it comes to cars, and the i20n will be my first car. Currently i am just trying to calculate the approximate maintenance cost for this car and i noticed that the 225/40R18 tyres are significantly cheaper than the stock 215/40R18 tyres, however it is not clear to me if this wider tyres will just fit on the stock wheels? or if i have to purchase a new set of wheels to fit the wider tyres?
Ok thanks,just seen your replyYes they will fit without any issue - I did this before I changed my wheels. The price of tyres is directly related to how popular that size is - 225 width is much more common, as standard, on cars than 215 (which very few manufacturers fit).
