Ok.
Rear seats are easy, as it is only mechanical work, no electrical connections. As i already told, the passenger seat is also easy, as all needed cables and wires are present.
You just must be sure, that you order seats for the same driving side as your car. There are many seats from UK on the Ebay, but they will not fit LHD car. Harness is different.
For the driver seat you need some elecrical modificatiobs in the floor harness. I did it myself, but if you not sure, you can deal with the qualified technitian. The bigger problem is to find components.
I ordered the seats from Poland. They have a market site allegro.pl, very similar to Ebay, but works only in Poland. There ere many used parts offers there. I found a partner, who bought seats for me in Poland and then send to Russia for some additional money.
While waiting for the seats delivery i started to study electrical schematics. I understood, that the drivers seat is controlled by the IMS module. This is Integrated Memory System module, it is located below the driver seat and actualy this is a part of the seat. IMS is responsible for the seat ajusting, it is also can remember seat, mirror and interior lights settings for 2 drivers and can restore them when you push button.
IMS gets power from the IPGM module. IPGM is a big fuse box near the drivers left knee. it delivers power to the different car modules and systems.
If you look the scheme, you see, that there are two wires between IPGM and IMS modules (grey and red). You need to add them. You also need to connect ground wire (black).
From the seat side you need to add wires to the FS11 connector, which connect floor harness to the driver seat:
From the IPGM side you need the I/P-C connector:
You need to connect pin 23 of I/P-C with pin 15 of the FS11. And also pin 33 I/P-C with pin 8 of the FS11. And pin 21 of FS11 connect to the ground.
The biggest problem was to find pins to fit the connectors.
After some search, i found that the FS11 can be purchased as a spare part:
18790-02003AS
For the IPGM connector the only chance is to buy some used harness and disassemble connector.
After recieving all parts i disassembled the seats. Also took off driver knee airbag an plastic arond it and IPGM. Then also took off the IPGM itself. After it added some wires between IPGM & IMS modules and installed new seat.
This was the first step on installing the IMS system.
If you want to have full system, you also need to:
- connect IMS module to the CAN bus of the car
- install door modules (control mirrors with memory)
-connect them to power and CAN
-install mirrors with memory
-connect them to the mirrors
