Wheels Protrack One 9x18 et 50
Philipp_I30N
6
Austria
Hey guys,
I'm debating buying a set of Protrack One 9x18 et50 . Does anyone have them on their cars?
I'm currently running the stock suspension with Vogtland lowering springs . I'm not sure if they will fit; that's why I want to ask you guys.
What do you say? Will they fit, or does anyone have them on their car with stock suspension?
I don't have them, but make sure to post pictures in the N-cars Rims Database once you have them :)
9" ET50 could be too much, as the maximum most people (legally & without rubbing) have is ~8" ET45 and yours is >7mm more out.
Hey guys,
depends on the tire you want to run. I know multiple people (me included) who run them without any rubbing.
should fit in 235, you might need to put a bit of camber on it.
Not sure if the lowering springs are too much, but I run a KW v3 Clubsport which has a similar lowering and it works fine.
Hey guys, I know it's nearly a month now, but I waited until my front brakes also needed a replacement so I could do both at once . The wheels fit nicely with my Vogtland 30mm springs, no spacers used.
Reactions: Felix
