Can I put a new spin on this thread and ask if any members have owned or currently own a late model VW Golf GTi with similar sized wheels/tyres.
If so what sort of tyre life have they received ? Just trying to work out if the i30 N is hard on tyres or if this is normal for vehicles that have similar performance. I am guessing we would like to know what brand tyres too.
I changed from a 2.0 TSI Scirocco with stage 1 remap so 250bhp and 300lbft torque. Michelin PS4 not the s version. 6k miles on the front so I'd be ok with the numbers being talked about. I only do 6k Miles per year and virtually no motorways or dual carriageways. I only use to get 8k from a set of front tyres on my 125bhp ford puma as well so could be my driving I guess.
I'm surprised at the wear some of you are reporting. Maybe I don't drive hard enough ha ha. the wife has a 30D X3 with P zeros. She's on about 36,000km and they still look like they have 70% life left. Having said that, I'm going to go with the Michelin PS4s next.
Any chance of a ECU update to only dip ONE mirror???? I like to have my road side mirror still pointing straight back so I can see oncoming traffic.
My last car dipped the mirror on kerbside only (depending on the mirror switch). If the switch was in the centre, no dip. If the switch was on L, then the left side dipped. And if the switch was on R, only the right side dipped. Obviously, as we drive our cars on the correct side of the road (not the right side), I want only the left (kerbside) mirror to dip.
No, I wasn't "told". But the tyre placard on the inside of the driver's door specifies Y rated tyres for both the 18 and 19" wheels.
Insurance companies will wipe you instantly if you have tyres rated less than the specified speed or load ratings. One of the very first things they look at.
So speaking to the underwriters at work they have said that they don't mind what tire you put on the car the only thing they care about wheel wise is the alloys...
Sooo if you want to change the tires it won't affect the insurance (still better check though as all insurance companies are different)
Reactions: Greenfishman
Ok for all you tyre geeks! Here is a chart showing all my tyres with the tread depths measured in mm across all of the 4
wear indicators, the depth gauge I used isn’t super accurate but gives a good idea of the wear pattern and takes out the guess work.
Hopefully the chart is relatively self explanatory but if you imagine viewing the car from above with the front of the car at the top........... you get the idea.
Interestingly my cars done 982m, the first 500 by someone else, the last 482m the tyre pressures have been spot on.
Looking at the chart I don’t see any evidence of toeing out/in etc but it does suggest the pressures have all been low or the car has been ragged sideways a bit!
Definitely low pressure running.
Also, outside NSF should be most worn (right hand roundabouts in UK) so that ties in as well, although I would expect to see outside NSR to be next. Swap your lefts and rights over as per manual and you'll extend the life.
I must check mine this week. I've done 5500 miles. Yikes..
Reactions: Mark46 and Stash-N
I have had really good experiences with Michelin Pilot Sport 4 tyres on my Mazda 6 MPS. Different car, different kind of drive system but similar power and a bit heavier so more weight to keep stuck to the road. And sticking it most certainly does. To be fair, I'm not the most experienced with performance cars but I've never felt as confident as on the Michelins to throw the car into corners at speed.
So if these Pirelli tyres are wearing as quick as some are saying, I'll probably go for Michelins again.
Reactions: padigree
I looked at the owners manual (7-29/30) and it recommends rotate at 7500m, my tyres will be like banana skins by then so I will keep an eye on them, I’m guessing I will be rotating them around 4000m.
Also if you look at the rotation drawing it shows a different rotation pattern for the 18” and 19” tyres, for the 18” tyres It recommends to put the fronts on the rear diagonally and put the rears on the front keeping them on the same side.
Weirdly the 19” only swap them over on the same axel?
Anyone know why there’s a different rotation pattern for each size tyre? Or have I misread something?
I saw the same. Does seem odd to have different recomendations for 18 and 19 wheels. I wondered if it might have something to do with the LSD, but I don't really see how.
Surely all 4 wheels and tyres are the same so I don’t get it, the 18” rotation looks like the correct approach.
But like speedking hinted when I eventually get through to speak to someone I will probably get the puzzled face response.
It's an interesting proposal, but then you would hope that the manual would differentiate between cars fitted with e-LSD and not, rather than 18" and 19" wheels.
The reason they have different tyre rotation pattern would surely be because of the type of tyre installed. I assume the 18" are asymmetrical tyres, and I assumed (wrongly) that the 19"s are directional.
A directional tread pattern is designed to roll only in one direction. That's why you'll see arrows on the sidewalls pointing in the direction that tyre needs to be mounted. They can only be rotated front to back. Right hand tyres MUST remain on the right hand side of the car, and same for left.
An asymmetrical tread pattern has a different tread (and possibly different compounds) on the inside and outside of the tyre. So, they can roll in either direction, but the outside of the tyre MUST BE on the outside of the rim. They can therefore be used on either side of the car, unlike directional tyres.
Any size tyre can be either. VERY STRANGELY the Pirelli P Zero's are assymetrical, so NO reason why they can't be diagonally rotated.
The diagonal rotation method (including the spare if it is a full size) has been used for ages, and seems to be accepted as the best method to even out tread wear across all tyres. You would only use the "front to back" method if your tyres are directional.
A good video about the differences in tyres (from a larrikin Aussie ex-journo):
Skip to 8:45 for the explanation... (he does waffle on)
So, like Mark46, is there a good reason NOT to rotate the wheels diagonally???
I think I'd always prefer the grippiest tyres on the back, therefore, I will rotate fronts and rears left to right as per the manual. Then when the fronts have worn, which they will inevitably do first, I will put the replacements on the back and bring the partial worn rears to the front.
I don't like losing my back end in a front wheel drive car..:(
I’ve done just that on mine! Haha! I love the rear end moving around! It’s so easy to fix on a FWD car, steer in (if necessary) and plant the throttle it’s got enough power to pull it out! :)
Reactions: Stash-N
I had a bad experience in my first car. Practicing hand brake turns and wore out my rears, then, on a leaf strewn damp surface, I binned it into a tree :(. Not pretty, and when you're only 18, the memory stays..lol
Reactions: Stash-N and paul-h
That definitely would stay with you! :oops:
Reactions: Stash-N
So ive done 10K miles and rang Hyundai for a quoute on 2 front HN Pirellis.
Uon hearing £380 fitted I began to wonder if I can but the exact same P zeros on but not HN.
The guy in servicing told me that the LSD required the HN tyres as it works to the tread pattern on them and he did not recommend other tyres o_O.
He also said as my car is on PCP lease, I cannot return it to them without the HN tyres on at the end of my deal.
Guys, I can put whatever tyres I want on it right?
and what do you guys recommend. obviously want something grippy, but not something that's going to burn out after 4-5K miles.
And dealerships wonder why the general public view them in such a dim light... :rolleyes:
Interesting take on things - I doubt it's true, sounds like the sort of thing that must've cropped up before with other cars using bespoke tyres.
