Blimey, mines on 13500 and loads of tread left on the Pirellis.
Blimey, I've just clicked 5500 miles and I'm looking at changing my fronts. The outside edges are pretty much slick now. More so on the left wheel. Can't resist those roundabouts.
Doing a track day at Snetterton next week. That'll probably finish them off.
You've got emptier roads up there, not the case down here near Stansted, I use my bike for real progress.😁😁
Hi,
Has anybody encountered this same issue, when the weather is cold(not icey). l come to a T junction at the end of my road and turn the wheel to pull away at the junction at maximum 3 mph and the front tyre seems to jump on the road for a split second as if it has no grip and creates a very loud thud sound in car, was wondering if it is because the rubber on tyre is cold, or is it something more sinister. Does not happen when tyres are warmed up, is this common with Pirelli Tyres on this car?, as I’ve never encountered this with other cars and Pirelli’s. Any help appreciated. Thanks in advance.
WAG29
GOOGLE "Ackerman skip". Some tyres / cars are more prone to this. My I30N does this all the time at this time of year when tyres cold, road damp and I've got some serious lock on the steering wheel. Think I comment previously that my RS Clio was very prone to this as well. Sounded like a wheel was about to drop off:confused: Nothing to worry about.
Long story short: when temperatures drop under 8°c change to wintertyres and the problem is gone (saves you 36 pages of reading).
O, and dump the Pirelli's for Michelin PS4s ;)
Yep when I had Pirelli’s I had this nasty surprise at a car park I thought the car was broken
Since having the PS4S it does it less but is still occasionally noticeable
Hi Guys,
I'm pretty new to the nitty-gritty of cars, so please bear with me!
My front Pirelli P-Zero developed a bulge after around 7k miles, so needs replacing. I have read around here that the Michelin PS4S is a good tyre. I am currently evaluating the following options and was wondering what would be best?:
1. Replace single tyre with a fresh stock tyre
2. Replace both front tyres with Michelin PS4S with the same dimensions as stock
3. Replace all 4 tyres with Michelin PS4S (I still have 5mm tread on the tyres)
4. Replace all 4 tyres with 18" Michelin PS4S.
I'm not really sure what the best sizes are in terms of width, sidewall height etc, but I basically want a tyre that is decent in all conditions at low and high speeds, for mostly road use with maybe 1 or 2 track days a year.
Any and all advice will be greatly appreciated!
Hi Guys,
1. NEVER do this! Always replace at least both tyres on the same axle, never just one.
2-4 depend on what you want to achieve. If you say you want it tailored towards cruising and comfort, go the 18" route with number 4.
If you like 19", go for number 2 or 3 (depending on your budget).
Thanks Bu11et!
In terms of width, sidewall height etc, is there anything to think about or just match stock?
Thanks Bu11et!
it depends.
If you are running the stock suspension - don't worry, everything's gonna fit.
If you are running 30+mm springs and a 8.5+" wide rim (or 15+mm spacers), it may be a very tight fit.
Goodyear eagle f1 asymmetric 5’s are going on my car in the Spring. I’d always replace both tires on the same axle as others have noted.
I removed the shocking Pzero and fitted new PS4s's 2 weeks ago and straight away it was like night and day. More grip, comfort i cant explain it but i wish i did it sooner. My Pzero where fine and sold them to another N member but i didnt trust them.
it depends.
do you own the P4S? I‘m thinking about the P4S‘s but littlw bit worried, because I‘m going to buy new rims to 8,5x19 ET45. But stock suspension (Fastback)
Don't worry. I have that combo on a i30n hatchback and there are no problems, not even with 4 persons and luggage for a holliday in it.
