Hello,
I just use this thread for a question to the turbo inlet in general.
Stock there is a kind of wire metal clamp with a bolt. The clamp should put force on the bolt so it should be secured from loosen.
Anyway I am wondering of the stock thread-in length/tightness is correct on my engine?
I tried and I can wrench the bolt tighter with little force.
I would appreciate if you could check it on your stock inlets from factory. That would be very kind.
Thank you in advance
