N-Light seats fitment in I30N (Pre)
Hey man, I was going through some papers and found the receipt from the dealer. Reference for right one (the one that was popped in my case) is 80620S0000. Maybe you can fins the left side with this PN... Good luck!
Awesome! That helps a lot, thanks! 🙏
Hello, is the item you purchased - 80620S0000 the airbag itself or the entire set of the airbag and housing that breaks when the airbag detonates.
Does anybody know if the N-Light seats can be installed in the I30N pre-model? From what I read in the Veloster, the fitment was exactly the same, only need to work on is to connect the dome lights to the N-logo, similar to how polaris xpedition accessories are fitted as aftermarket upgrades.
Has anyone been able to do it?
Thanks!
Yes, the N-Light seats can be installed in the pre-facelift i30 N. The physical fitment and main connectors should be the same, so the seats themselves are essentially a direct swap. The main thing you’ll need to deal with is the wiring for the illuminated N logos. You can connect those to the interior/dome-light circuit so they come on with the interior lighting. Before installing, I’d still compare the seat connectors and airbag wiring between your existing seats and the N-Light seats. Other than the N-logo lighting, it should be a fairly straightforward conversion.
Reactions: kennethvde
Hi, I recently swapped the comfort seats in my i30N Fastback for the N bucket seats. Everything is perfectly plug-and-play—even the seat heating—except for the seat lighting, which doesn't work. I’d really like to get that working, but I have absolutely no idea how to go about it. Does anyone have any handy tips (and maybe some photos) on how to wire this up properly? Thanks in advance!
