Managing i20N inlet valve deposit accumulation . . .
Automate
88
40
Australia
What experience have other i20N owners had slowing down the accumulation of deposits on/around the inlet valves, given that we do not have any fuel injected before the inlet valves to help clean them?
Does anyone have any experience (and even better any measurements) using products like "CRC GDI IVD Intake Valve & Turbo Cleaner" (for example) in a partially preventative maintenance capacity, and what has been your experience, and if positive what insertion point do you recommend using for the above cleaner in the i20N?
In my case, I only do about two 16km long trips per week, plus a longer trip every now and then (perhaps once a month), in the i20N.
Thanks.
Well you ask a very good question but I can’t say I’ve ever seen any specific discussion about this issue relating to the i20N. There are a few catch-can options made but how effective they are, or even if they are really needed, is not something I’ve seen discussed.
The only thing I can say is Hyundai on every service put a fuel indicator cleaner through the system I personally use the genuine one every 5,000 km when I change my oil so I recommend that you do that at least as the tips are in the cillender so can get carbon deposits and effect the spray pattern. I recommend that you do that regularly.
Thanks for your replies YNWan and RowdyN.
Since our i20N engines are Direct Injection into the cylinders, apparently no significant amount of petrol is able to clean the inlet manifold or behind and around the inlet valves, so it is my understanding that injector cleaning fuel additives cannot help us much in regard to cleaning the inlet valves (even though they can help clean the injectors).
Apparently there might be a little fuel sprayed onto the inlet valve to some extent from the cylinder side (deliberately by design), but i have no confirmation that this is so, or if it is significantly helpful for the i20N motor.
I am most interested in hearing practical feedback from i20N owners about this potential issue, whether it is something that owners doing mostly short drives need to do anything about managing, etc.
Thanks folks.
first we need experience from persons who checked the situation at the i20N inlet valves.
Before that, we can only assume that there could be a problem...
second I chose my engine oil with focus on lowest possible NOACK value.
If there is less oil evaporating, less oil gets into the inlet port through the crank case ventilation.
Reactions: Automate
Both the i20N and i30N engines have accumulated enough years of usage world-wide that if it was an issue there would be many postings on-line. Either we all use Top Tier Gas, and it works, or it's not an issue.
Yes we can hope
Several things do consider:
Good fuel
Good oil (Noack)
Of course a good construction with well oil absorption through the crankcase ventilation labyrinth/separator
And also driving behaviour >> process of deposit needs high temperatures to build up
Adding to the variables, how frequently the oil is changed, cold starts per distance traveled.
We just need one of us to do a borescope inspection to understand how big of a problem it is.
Reactions: Automate
As for oil
Ravenol DFE is one of the or the best 0w20 oil.
A real PAO, very low NOACK and also at the upper end of 0w20 viscosity grade.
Shall not be a oil discussion but it fits well to the topic
Reactions: Automate
