Hi guys,
bought an 2023 i30N Fastback a few months ago and adjusted the low beam height cause it was set way too low from the plant (had to move the screw 5/8 turns).
While doing so in a dark parking lot I realised that the left low beam is terribly blurred in comparison to the right low beam. It was hard to set the right height. I never had a car with such a blurred cut edge.
Has anyone faced the same issue in the past or could you check if you have a similar problem? I guess adjusting the screw for left/right adjustment won't change the sharpness.
Thanks in advance
JD
Thanks in advance
JD
