Those Braid wheels are race/rally wheels. Keep in mind that it's much harder to keep them clean. The paint isn't as smooth as on other wheels. I have them on a Xsara VTS and after a few years they need a respray because they look dirty.
Thanks Tom, that's worth knowing. Luckily I'm quite near Solent Wheel Services who I've used a few times and do a fantastic job of wheel repainting, they did this for my MX5 wheels, as you may tell I quite like white wheels!Those Braid wheels are race/rally wheels. Keep in mind that it's much harder to keep them clean. The paint isn't as smooth as on other wheels. I have them on a Xsara VTS and after a few years they need a respray because they look dirty.
I'd thought about going down the 18" route, theres far more options in that range, both in rims and tyres.
My only concern is alignment, somewhere in the deep dark recesses of my old, alchohol ravaged brain I have a memory of someone telling me that when you swap rim size (even if you end up with the same diameter) then you need to re-align your wheels?
Pretty sure you don’t need alignment done when swapping wheel sizes.It would, if I wasn't swapping from road (19's) to track (18's) - in my anal retentive world, I'd have to swap the road set for the track set, get an alignment, do my track work, swap back to my road tyres and get another alignment.....
I've never claimed to be normal, in fact I have a Doctors note (and medication) to prove it![]()
Unfortunately these are quite a bit more expensive in the UK or I would be interested.I would go for OZ Ultraleggera, 18x8 ET48/35 is about 8,5kg per wheel ( 19lbs ). They cost about 1100 € for all four. You can also get 18x9 if you can somehow fit wider tyre, or 19x8/9 if you don't want 18 inch wheel.
Shane,
I too am looking at track wheels. Have you considered a set of Evo X wheels? BBS, forged, light as (under 10KG), strong as, 18 * 8.5" ET 43 or 44 (perfect fitment). And they don't look like Mitsubitchy wheels! There were two sets on ebay / gumtree recently. $1925 and $1700 with tyres, but they appear to have sold.
I personally am going the SSR route. GTX01, 8.8kg, and black.
Cheers, David
Shane,
Cheers, David
