Tuning i20N Engine & ECU Tuning Discussion
Well I can’t disagree with any of the above that T0m_i20N states above. But let’s consider his 6 suggestions for reducing weight:
1/ I don’t have a spare wheel so that’s an easy one
2/ I could remove the rear seats as nobody goes in the back - or very, very rarely. I don’t want to remove the plastics as this would be a stage too ugly and they are pretty light weight. I may remove the seats but I would need a cover of some sort. Also, whilst the overall weight would be reduced it wouldn’t be in a very good place in that it would shift the balance even more toward the front (maybe that’s not an issue in a front wheel drive car?)
3/ Yep, I‘ve got light weight wheels
4/ I can’t remove the catalytic converter completely as it won’t pass the yearly MOT test without it - but I do have a sports cat and a GPF delete
5/ Removing the seats is also a no go for me. I do need a passenger seat and changing the seats to light weight ones is an issue as it means losing the seat mounted air bags and I don’t know how my insurance would feel about that. Keeping the heated seat option would also be nice.
6/ I actually have a suitable Lithium Ion battery (Deadweight Industries) and it works fine. However, such batteries don’t like short journeys as their protection circuit cuts in at quite a high voltage compared to a normal lead acid battery and makes it seem as if the battery is suddenly dead. I could keep the car on trickle charge but it’s not convenient as I have a drive, but no garage. But it is a lot lighter and may be worth another try.
Reactions: T0m_i20N
I think you're pretty much spot on for what the car needs to be on the road to maintain a level of comfort. What you find with the rear seats is that most of the weight sits in the backrests, they weigh nearly 20 kilos just themselves and they come out with a bolt and a firm pull up after puling the folding handle and removing some plastic retainers!
Lovely setup, which deadweight battery did you go for? I've been looking at them myself but I'm not quite sure which one to go for... obviously needs to retain all electronic functions and such
I’ve had the rear seats out when I fitted the rear strut brace so I appreciate they are easy to remove 👍.
The Deadweight battery I have is the Touge 500:
It drops right in and no mods are needed - everything works just fine but I would recommend one of those small battery monitors (that you can monitor with your phone) to go with it or you really have no idea of the charge until it suddenly shuts itself down and you can‘t get in the car 😆.
Reactions: T0m_i20N
In the spirit of investigation and acknowledgement of ‘Black Friday’ I have bought a Draggy Pro (£98.00). Unfortunately we are now heading toward winter in the U.K. and this is characterised by cold and wet, so not the ideal conditions for Draggy use/testing….. but U.K. weather is notoriously variable so we may well get some dry days and a few tests may be possible. If anyone has any suggestions as to what tests they would like done then please say?
It's been very interesting following the latest ECU tuning and it's something I might consider next year when the warranty expires.
All that i've done to mine is fit better tyres, RE003 in 225/40-18 and replaced most of the exhaust. Both of those gave real benefits. The tyres give more feel which you can feel best with the steering on the lightest setting.
I got the RPM 3" system, leaving the stock over pipe and cat in place, starting with the flex pipe and then the version with the 2 x 3" pipes from the muffler with one of them valved.
It was too loud so now it has a vibrant super quiet 3" resonator[see below] where the second cat was fitted in the original system[GPF in Europe]
I also fitted 55mm SS perforated tubing wrapped with exhaust tape into both SS rolled tip.
Now it sounds sweet and is not offensive. It's also more responsive with boost coming in much quicker and pulls harder, especially noticeable in 6th gear.
