Tuning i20N Engine & ECU Tuning Discussion
In the Revelation Performance vid the dyno graph reminds me strongly of old Big Fish results (not the ones they are able to tune now) where max power was made lower in the rev range and then tailed off.
I would get some Draggy results from my car but…. I don’t have one and nor does anybody I know.
I think just the scale of the graph makes it look a bit funky, this is what I mean by weird dyno's haha, but there is still some dip at the end and that is to be expected on a smaller turbo, the turbine wheel just turns in to a flow restriction itself.
You could ball park it using the built in acceleration timer on the N mode screen on the centre cosnole, as far as I can tell that uses GPS rather than the speedo. Obviously do that on private land wink wink...
not sure if it has been posted already, the guy from pro boost engineering (who works closely together with MTTuning on their i20N efforts) has recently posted a video about his work. Its in german, but I think english subtitle might suffice.
I did see this, used the auto translate feature to watch. I think he, like others, has found a way to bypass boost limits in the factory software. I believe he's a german tuner, main competitors will be klasen and MT tuning, I believe MT is working on this himself/has already got past it from my own conversation with him, I have no info on Klasen's progress on this
I hadn’t seen the ProBoost video before so many thanks for linking to it Bu11eT and the subtitles work extremely well. To be honest, everything he says and has achieved seems very like that which Klasen have done but with the addition of a hybrid turbo.
Reactions: T0m_i20N
It seems like tuners are finally getting a handle on this ECU. At the end of the day though the turbo is only good for around 250HP according to Borg-warner. Tuners in turkey are using Water/methanol injection (or hybrid turbo) for 260+HP from what I have seen which is not something most would be comfortable with probably. WMI is not legal where I live. I kinda feel like 240HP/360-380NM torque is a nice place to be with this engine. It doesn't have 255 tyres or the weight up front to put high power down at low speed so it seems like 300+HP is not really useable (at least to me in Aus with 110kph speed limits and hoon laws that wil seize and CRUSH YOUR CAR for exceeding 40km over the limit. I love that people are exploring the limits of the ECU because I find the engineering and everything else about this car fascinating, but I wonder if it defeats the purpose? It's a wonderful car to drive in stock form IMO.
My car has a hybrid turbo and produces 298hp on 99 Ron fuel. It’s quite happy to be driven daily and runs fine. However, if the roads are at all damp it’s not difficult to spin the wheels so some care has to be taken (I’m not sure what traction control the i20N has but it’s very subtle in its intervention).
The blue lines are my previous tune and the red are when the hybrid turbo was fitted. The top graph is horsepower and the lower is torque.
And it's great to see people like you exploring the limits of the vehicle, I have watched with interest and will continue to do so. I think there is still more to learn about the platform but an undersquare engine is generally more suited to torque output rather than outright HP. I have been waiting to see if any conrods or bearings fail at 400+NM but so far it seems to hold up. Are you still running the stock clutch/flywheel? I think less reciprocating weight would improve the engine response nicely. It used to be one of the first things we did to our cars back in the 90's. Of course we had single mass flywheels back then so it was cheap and easy to machine the stock flywheel on a lathe which is not an option on the i20N.
Reactions: T0m_i20N and YNWaN
Yes, I’m still running the stock flywheel and clutch and this is mainly because the clutch is (currently) fine. I agree a lightened flywheel would likely be an advantage but it does actually rev quite freely. Anyway, when the clutch does need replacing I will likely upgrade both.
Reactions: FlamingHedgehog
I will be interested to read your observations if you do. I have not seen a lot of feedback for this mod.
