HDT Motorsports I30N exhaust parts (Downpipe, Flexpipe and GPF Dummy)
Kchar
Active Member
183
115
43
Athens
Good evening,
The following HDT Motorsports parts are available for the Hyundai i30N:
• Downpipe – €1300
High‑flow downpipe with 89 mm diameter from the turbo, tapering to 70 mm. Direct bolt‑on fit to the stock exhaust with no modifications required. Equipped with an Euro 6 HJS 200‑cell catalytic converter.
• Flexpipe – €150​
Features 70 mm inlet and outlet flanges, fully compatible with the factory exhaust system. The OEM flexpipe narrows to just over 50 mm internally, creating significant backpressure. Replacing this part alone you can gain over 7 hp.
• GPF Dummy – €150​
Large 130 mm housing with 70 mm connection diameter. Significantly reduces backpressure, increases power and torque, and delivers a more aggressive exhaust note. Sensor mounts remain in their original positions and function normally with no error codes.
Parts are located in Athens, Greece and a better price can be offered if the parts are purchased as a set.
