Here is how Copilot replied quite informatively to the question "Can you achieve better performance or longevity by using different types or brands of tyre on the front to on the rear of an i20N?"
Short answer:
no — not on an i20N.
Long answer: it’s one of those ideas that
sounds clever, but once you dig into how the i20N behaves, it almost always makes the car worse, not better.
Why mixing tyres front/rear is a bad idea on an i20N
1. The i20N’s chassis is tuned around equal grip
Hyundai set up the i20N with a very specific balance:
- strong front-end bite
- predictable lift-off rotation
- stable high‑speed behaviour
When you mix tyres, you change that balance in ways you can’t fully predict. Even small differences in compound, carcass stiffness, or tread pattern can shift the car toward
understeer or
snap oversteer depending on which end has more grip.
On a front‑wheel‑drive hot hatch, that’s not something you want to gamble with.
Performance: why mixing usually reduces it
If the front tyres are grippier than the rear
- Turn‑in feels sharp at first
- But the rear becomes nervous, especially in wet conditions
- Lift‑off oversteer becomes abrupt rather than progressive
- ESC intervenes more often, slowing you down
If the rear tyres are grippier than the front
- The car pushes wide on corner entry
- Torque steer feels worse
- Braking stability suffers because the front tyres lock earlier
- You lose the i20N’s playful rotation
Either way, you’re compromising the car’s natural strengths.
Longevity: does mixing help tyres last longer?
Not really.
Front tyres wear faster on the i20N because:
- FWD puts power through the front
- The car has aggressive factory alignment
- The LSD loads the outside front heavily
- The car is relatively light in the rear
If you put a harder or cheaper tyre on the front to “save money,” you end up with:
- worse braking
- worse wet grip
- inconsistent handling
- more noise
- uneven wear patterns
If you put the harder tyre on the rear, you get:
- unpredictable rear‑end behaviour
- reduced stability in emergency manoeuvres
The only reliable way to increase longevity is:
- choose a tyre with good wear characteristics
- rotate tyres every 5,000–7,000 km
- run correct pressures
- avoid excessive toe‑out
The only time mixing tyres can make sense
This is rare, but worth mentioning:
Track-only setups
Some FWD track cars run:
- semi‑slicks on the front
- road tyres on the rear
This is done to increase rotation and reduce understeer.
But on the i20N, this is:
- twitchy
- risky in the wet
- not suitable for the road
- not recommended unless you’re an experienced track driver who understands the consequences
For street use, it’s a no-go.
The best real-world approach for an i20N
If your goal is
performance,
longevity, or
comfort, the best setup is:
✔ Same tyre model on all four corners
✔ Regular rotations
✔ A tyre that suits your priorities (grip vs wear vs comfort)
Given Melbourne’s climate and your interest in balancing performance with refinement, something like the
Goodyear Eagle F1 SuperSport or
Michelin PS5 gives you the best all‑round result without compromising safety or balance.
If you want, I can break down which tyres give the best
longevity,
wet grip,
comfort, or
value specifically for the i20N.
