Interior Dashcam finally installed.
The cable ive ordered its the thickness of a USB C male end so not far off a cable tie 🤔 cables gotta arrive first, if it doesnt fit no big deal as ill just then go the same route as you
Reactions: Capt. Perfecto
That's as far as I got 😁. I could only fit the thin end of the tie through, the lock end had no chance. Hopefully your cable is thinner than mine and you can squeeze it through🤞.
Really is tight in there huh, i think the rigidity of the connector is stopping it, thinking of desoldering the connector, feeding the wire and reattaching the connector. Have a spare cable to test before i bother. Buut its wanky weather in the UK now so it might wait
Just got mine installed.
Thinkware U3000.
The rear cam is low on the back hatch window to the passenger side of the wiper.
Can take pics on the weekend i guess when i have time and light available.
Thinkware U3000.
I'm keen to see pics of your install and a bit of a performance review would be nice too, if you have time. Thanks.
Havent had the car for the past couple of days while getting PPF protection installed on the front (which should indicate I am serious about keeping this car for 10+years). Will get to the Dashcam pics soon. probably.
Reactions: Zealot
I payed a bit of a premium to get a model that has the parking mode with radar detection, but i think it was worth it. the detections are much more relevant than the ones we get on the car we installed a U1000 onto which uses camera detection.
The impact detection does pretty much always tell me there was an event while parked, because it detects me getting into the car. Its also detected 'impacts' while driving down some roads with broken surface, but thats probably more down to the i20N stiff suspension than the camera.
Sorry for the slow response and hope the installs are working well for you all. I've had no issues with my install, very happy with it. The cable for the rear is pretty thick so I was anticipating some rattles but fortunately that only really happens on rough tarmac and isn't all that bad.
The camera's do lock files from a rough bump in the road thanks to the slightly stiffer suspension as mentioned above but it hasn't been a problem yet. The low-voltage gate is a must have as parking mode does draw a bit from the battery.
So after much trial and error and different cables ordered and ideas tried ive got mine fitted and am happy.
For anyone wondering the rear usb port (as least on my car) does not have a strong enough output for the first few miles so my cam was turning off and on when I braked, went into reverse and especially with the lights on at night so I ended up getting a usb splitter that went from dongar adapter for thr front cam already and finally got that sorted already.
Forgot to take a new pic with the usb splitter in dongar but the original connection for the front is here
And my thin cable fit through the gromit to the boot and through the inner spoiler gromit but ooof it was a pain to feed it through
Have got an oem gromit coming I can cut so I don't ruin the one from the car with the cable through the middle of it
For anyone who has a dashcam with parking mode:
If your dashcam reduces the battery voltage, you may get battery warnings from you car if you don't drive it for a few days.
Also, you will find that the auto stop-start feature doesn't work after your car has been parked overnight, at least until you drive it for a while to top off the battery.
I have heard of this from someone with a Blackvue and I had started noticing it with my Thinkware on colder mornings (might not be low batt, the stop-start may never work until the engine warms up and the weather hasnt been cold in general since it was delivered). My Thinkware has a configurable voltage cutoff and very low parking-mode power draw, so I thought I'd post some feedback.
Last night I changed the cutoff volts up from 12.2v (advised by the installer that this is fine for most people) to 12.3v. I also set the parking mode to the lowest setting without turning it off. This morning I didn't need to run the AC/defog, etc so was happy to find that stop-start worked after the car had been parked overnight.
TLDR: If your dashcam parking-mode eats your battery overnight then you might need to adjust your cutoff volts, or add a dedicated dashcam battery option, or reduce your parking-mode settings.
EDIT: following morning with cold temp, stop-start didn't work, but the engine didn't even really get fully warmed up, so probably engine temp related more than battery? next time I'll let it warm up a bit more.
Tried posting elsewhere in this forum, when I should have just added on here. Seeking some advice with installing dashcam on the wife's 2025 i30N Premium. The dashcam unit is a Viofo A139.
Seems the Hyundai unit on the windscreen behind the mirror has changed from previous years, and no longer has handy channels in the plastics to run the dashcam power cable (see photos).
Attempting to install the dashcam under the Hyundai windscreen unit behind the mirror would mean the dashcam power cable would be impossible to run. As you can see the dashcam power cable goes in at the top.
So I am wondering. Those of you with 2025 i30N that have installed a similar dashcam, where did you install it? I have a bad feeling I will have no choice but to remove my road toll tag and install the camera in that location?
The right hand side is likely to block vision on the side of the mirror.
Appreciate any suggestions.
So, I finally got around to buying and fitting a dashcam in my car. I've owned the car for over a year but I felt the dashcam system I wanted was always overpriced so I was happy to wait for the inevitable reduction. The recent Amazon Prime day saw just such a reduction and the price dropped to something far more agreeable.
I've seen a lot of dashcam installation questions but not much in the way of guides so I thought I'd post my experiences.
This is in no way intended to be a tutorial, this is simply how I tackled the installation. All references are to a UK car, overseas models may differ. Any installation is at your own risk (but its actually quite straightforward).
This is the dashcam I opted for:
The Viofo A139 Pro 2 channel camera (2 channel just means I get a rear facing camera that records from the back). More info here (no affiliation whatsoever): Viofo 4K A139 Pro 2ch. I also bought the dedicated hardwire kit and a cheapo fuse tap. BTW, for those that don't know, the i20N uses Micro 2 sized fuses.
A quick note about the hardwire kit. There are many kits on the market that would do an equally good job at a lesser price. I have hardwired Viofo cams before on other cars and their kits have a voltage shut off protector built in. They have a voltage selector switch with a range from 11.8V to 12.4V. This means if you enable 'parking mode' on the cam, the cam will switch off if the voltage drops below what you select on the switch. DO NOT set the voltage to less than 12V. If you do this, you risk flattening your battery and not having enough charge to start the car. I always leave mine on the highest setting (12.4V), but the choice is yours. You have been warned. Also, make sure the hardwire kit has 3 cables if you want parking mode to work.
Another quick point with the hardwire kit. If you decide to go with an alternative kit, note the orientation of the USB-C (or Micro) plug. Many have a 90° outlet. This is fine depending on your choice of dashcam, but the A139 has the power input on the top of the unit so ideally needs a straight USB-C cable, especially if you want a neat install. If you're not bothered about tidy cables, then the choice is yours but consider the routing and the fact that the cable might have to bend back on itself in order to tuck around the headliner.
This image is the top of the dashcam I bought. You can see why a straight USB-C is preferential, along with the issues a 90° cable might bring:
So, to the installation itself.
The camera sits behind the rear view mirror, positioned so the power cable has a straight run between the mirror mount and the rain sensor:
The only slightly awkward bit was tucking the choke on the USB cable under the headlining. If you look at the image above, you can see a very small bump to the right of where the cable disappears. It is 100% not noticeable when you're sitting in the car. The cover for the rain sensor just pulls off so the cable runs through the headliner, above the wiring for the sensor, then past the next sensor cover (not sure what it is, but that cover unclips easily as well), and goes over to the A pillar. Once you reach the A pillar trim panel you can pull the top of it away so you can route the cable into the weather strip. You'll have to pull the weather strip down to make enough room for the cable to go behind the A pillar trim. The cable then runs down behind the weather strip and into the fuse box behind the panel at the bottom of the drivers footwell:
Here you can see the weather strip pulled back and the cable disappearing into the fuse box:
Wiring to the fuse box was very simple.
There are 2 empty fuse locations on the box. The one circled top left provides constant power, and the top right is powered on ignition or ACC. So, main power is to the ACC (top right) location, if you want parking mode enabled then this is the top left. From memory, power comes in from the left so bear this in mind when you plug in your taps. Power has to come in, flow through the fuse, then go to your camera. This is how it looks after the fuse taps are installed:
I cable tied the excess and tucked it to the left of the fuse board out of sight. The grounding point I used was a bit of a pain. There is a random nut welded high up to the right of the fuse box. This was the only semi-convenient grounding point I could see. The 2 bolts above are NOT grounded, unfortunately. Unless you have tiny hands, the only way to access this nut is to remove this panel:
It was a bit reluctant to come off but once removed, you have full access to the nut. Start by prying it off gradually and once you can get a finger underneath it'll pop off. The thread is M6 so I found a nut in my stash to attach the ground:
Either side of the nut would be OK to attach the ground, I just chose the inside.
I'm limited to 10 photos per post so have not posted anything relating to the rear mounted camera. If anyone would like a similar rambling post on how I installed this then please let me know.
In the meantime, hopefully this might give someone a few pointers. Any questions, please let me know and I'll do my best to answer. I am NOT a qualified installer/auto electrician but this is really not a difficult job to do and is made much simpler by having 2 spare locations on the fuse box. There's always concern over which fuses to tap into so this takes away any guesswork.
Good luck 👍 .
Going to be attempting this later on and using this guide. Thanks so much for the photos as now I don't feel so reluctant to open up that side panel, wish me luck!
Does you camera have parking mode? Does it work with Dongar? Cause I like this option of installing, but if parking mode is not working while the car is turned off, I will have not other option than to use the fuses kit.
I have also found these adapters but I have the feeling that they don't work while the car is stopped.
Nah the mirror is only powered when the car is on unfortunately but i also wouldnt want another drain on the battery over bluelinks drain as it is
In the end I installed mine using the hard-wire kit for having all features available. So thanks @Capt. Perfecto for sharing! This topic might go to https://n-cars.net/forums/forums/i20-n-how-to-guides-section.64/ section because has all elements.
I was wondering if there is any feedback after two years of use? I am using my camera for several days now and the hard-wire kit is set to cut the power on the camera at 12V, so most of the time I get a warning from the car when I start the engine that some electronic devices are draining power. I was thinking to set it to 12.2V because I don't use the car everyday so the parking mode is probably eating most of the battery between car starts. The camera it is set on auto motion detection.
Hi,
Glad I could help.
2 years on and all is still good, no problems with either the set up or the dashcam. I stopped using parking mode for the reasons you mention. My recent journeys have all tended to be rather short so I had concerns that I was not giving the battery long enough to get a decent recharge, hence I switched it off. To put this into context, my stop/start system rarely works and as this is linked to the health of the battery I did not want anything else causing unnecessary drain.
