I don't believe it's going to be a problem until around 60K or better with this engine.
Carbon build-up within the intake system. Many owners have now clocked up some reasonable miles/kilometres on their N cars.
Does anyone have any actual experience with carbon issues either with a catch can installed or without?
Finally got my oil analysis results back from Blackstone Labs and what do you know? Fuel dilution was <0.5%. So this means that with extremely minimal blow-by I was still able to capture a significant amount of oil (15ml) that is being vacuumed out of the valve cover. Next up is a 1000 mile catch can check after running Amsoil 0w-30 and possibly using a boroscope to peak at the turbo/valves etc. The first catch can results were with break-in oil so it will be interesting to see if the results change with a top of the line oil. Finally, the viscosity of the break-in oil was a tad thin for 0w-30. Makes me wonder what oil they actually put in the engine from factory.View attachment 9264
Nice. Did you stick to the Hyundai-recommended run-in process or nail it from the get-go?This is all I could get out of the PCV hose. The other hose was clean as a whistle. 4000km. The car had been driven a short distance an hour prior.
so, to summarise to not that enlightened individuals as I am, not that big of a need for a catch can?The amount that is displayed above avayswavay is negligible. Nearly all, would have been re-burnt in combustion.
What Davo01 got from his PCV and CCV hoses were nothing. With a recommended 15K BG valve cleaning interval, there will be little to no accumulation on the intake valves. Thanks @Davo01 for posting.
Correct, it's more precautionary. If you have to drive your car in short stop and go situations more than on the open roads, I would consider one.
Not as badly as you think. You are talking about two different engine in the Hyundai and VW. the VW bing the far worst of the two. The VW engine has considerable blowby which causes the coking problem far worse than the Hyundai 2.0T Theta II.
I can clearly see you're particular overreaction based upon the VW engine. I believe others have also. Not all GDI's are alike and so far, the Hyundai 2.0T Theta II isn't a problem. With a fuel dilution of less than 0.5% the amount of fuel/oil/water vapor is not a significant amount, nor is it near the fuel/oil dilation levels that most VW engine have.
Cleaning with the BG system at 15K intervals is not expensive and just good insurance for the long run.
The supporting evidence is out there from other VN owners. Some have actually removed their CC systems. The amount they're collecting is even less than what you've collected. Common sense and understanding fuel/oil dilution levels is necessary and not jumping to on substantiated claims. Frankly, your claims do not favor the use of a CCV/PVC CC system. Maybe if you were having twice or three times the amounts per oil change but not at the insignificant amounts you've demonstrated. Also combined with over 3.5 percent fuel/oil dilution which you clearly aren't getting. Even at a 3000 miles interval.
You first have to understand it's not the oil that cokes the valves. It's the combination of fuel/oil/water vapor. You're just not producing enough fuel/oil/water dilution or vapor. The oil you're catching is moved back thru the PVC to be re-burnt. The engine was designed to reburn this amount of fuel/oil/water/vapor. The majority of what you collecting is comparatively small and the valve cover filtration utilized on the 2.0T Theta II is working quite well.
To be frank, you can afford to be changing the oil every 5K miles based on the lab results. I also believe this is what the lab suggested as well in the comments. What you're doing is going to the extreme end, based upon your past experience.
The use of a catch can for either side is not mandatory with this engine, unless you're utilizing the car for a lot of short, slow speed trips and in stop and go traffic. You're attempting to convince other owners it's the best thing to do and clearly it's not, based upon your own results.
I've had similar results in oil lab testing in comparison and it just doesn't warrant the mandatory use of a CCV or PCV catch can. So it then comes down to, individual choice to utilize one or not.
Now, no one has equaled or surpassed 60K-80K miles as of yet, so it remains to be seen how much actual coking will occur. If owners are doing their the diligence; changing the oil at no more than 5K intervals, utilizing high quality spec synthetic oils and have regular valve cleanings, I see no foreseeable issues, as you experienced with the older VW engine.
You're speculating to similar coking issues, without a basis of factual information regarding the Hyundai engine, clearly. Most owners are clearly aware of how a GDI and multiport fuel injections engines work, so we can for go with the continuous rehash of researchable information.
You have no data to support your belief regards older engines verses, turbocharged engines. It's merely personal speculation. I understand you had a bad experience with the VW engine but this is your impression solely and past as well. It doesn't mean you'll experience it with the Hyundai engine. As the miles wear on from both the VN and i30N, everyone will be made aware of any such issues, if they become prevalent.
Personally based upon first hand information, you're testing as well. I certainly don't believe either the CCV/PVC catch cans are to be considered mandatory or will provide any additional preventative benefit if normal maintenance is completely by the owner.
