Interior Bose Amp
Murky
4
Belgium
Hello,
Im upgrade my sub from bose to a JBL.
I was wondering if anyone had or found the bose amp wire diagram since i want the sound signal before the amp?
I have tried using the already amplified signal that goes to the original sub but thats a no go.
The signal before the amp is SPDIF digital. Even if you did take the signal you wouldn't have any volume control.
As the volume is done through CANBUS. Not sure why your having trouble with the sub signal coming out of the Bose amp. You should be able to use that & connect to high level inputs of the new amp. Not sure why country your from, but if you wanted to upgrade the audio, it's better to get a car without the Bose installed.
Im from Belgium bose comes with it stock i had no choice; i tried connecting the new sub straight to the sub wiring but the amplified signal was to strong for the amp/sub it kept tripping into safe mode even when connected with high level input. I ordered a high low converter that can handle 40Volts might be a little overkill but ill be happy if it works.
I'm in Australia & we also just get the Bose as stock. What amp were you connecting it to?? Were you connecting to the high level inputs or just converted the speaker wires to RCA & connected that to the amp?
I'm using a Helix M One X amp without any problems, The amp can take up to 13 volts of input. I'm also using a Helix DSP connected from the speaker wires in the high level input without any problems..
The low level converter if it handles 40volts will work perfect for you
I bought myself a jbl bass pro go since it was pretty easy to install since it has auto turn on via signal. But when i received it the original box was damaged pretty badly in the shipping so perhaps there was something wrong internally. Anyways it was supposed to handle 16v max on high leve input. Its now on its way back to where it came from for a refund and im going to get a Ground Zero bass kit with like i said a high low converter.
On the i20N? Is it a completely different head unit for the Bose system then?
Do u perhaps know which wires go to which doors ? That would help me out a lot since the original sub signal gets cut at around 80hz; And my new sub can handle 30-200hz.
That I'm not sure as I haven't seen any pinouts from the non Bose headunit.
Speaker outputs are on the green plug. You will still best to use the Sub output. As 80hz is ideal for subwoofers.
This is how I've got mine wired up with adaptor plugs so it can easily put back to stock is needed,
This is gold! Where did you get the adapter plugs from?
Great info! I bought the above adaptor and the connectors do fit perfectly. From there I'm planning on running the speaker outputs through an amp and straight through leads for centre, nav and voice back to the speakers, does that sound like it will work? I understand some blending will need to be done to control the chimes but I've got a guy that can do that. Also some of the connectors are different colours on mine but the wiring looks the same as yours and the pinout seems to match up.
PXL_20261115_030100475.NIGHT.jpgPXL_20261115_030107592.NIGHT.jpgPXL_20261115_030134498.NIGHT.jpgPXL_20261115_030838693.NIGHT.jpg
