Another exhaust spring thread....
kamyk155
915
1,030
Poland Gdynia
Hi guys. My problem was typical - small exhaust rattle like small coin jumping inside right exhaust pipe (this with the flap inside).
I had ASR spring ordered years ago - just in case of this situation and few days ago I went to hyundai service and told them to swap it with oem spring because of the rattle sound.
You wont belive guys......it wasn't the spring. They unscrew the flap box and punched the exhaust with hand....metalic sound was still there.
Service man asked me to come and see - because I have Remus exhaust and the end tips are "dual pipe" - main exhaust gas pipe is inside and other cover pipe made from carbon is outside. IT WAS A SMALL ROCK between them jumping and making that noise.
This should be end of this stupid story but I told them - you opened the box so change the spring to new one anyway because it is 8 years old.
ASR spring was smaller than oem one and someone here on the forum even saw that it was a bit lower.
After exhaust spring change I took the car, run it, set my typical N custom and...... why so quiet ?!
Drive some more changing drive modes. After few minuters I started to hear pop and bangs but really quiet. Normal/eco - no popcorn, N/custom - quiet but pops/bangs. I drove for now about 200km and still really quiet.
More exaples - before - inside my garage after I started the car and after few seconds changed to N mode sound was instantly deep and loud.
Now - starting the car in the garage - quiet sound, switch to N - zero changes in sound.
Driving on N mode sometimes even at 5000+RPM don't give me exhaust pipe shoot - only some popcorn.
So....the spring hmmm is working because normal/eco is totally quiet, but N/custom is way more quiet than oem but still pop/bangs are present.
Now I'm thinking about few things:
1 - ecu reset - some ppl say to disconnect the battery for 20-30min
2 - wait more for spring adaptation (it will heat or full click inside)
3 - buy new spring - this time from RPM or other - those with more wraps/scrolls and higher than oem
4 - try to put oem spring again inside ?
I saw another weird thing too - starting the cold car - RPMs are droping after few second from 1400 to 1100-1200 and this was normal because of cold oil need some time to flow, but now when I press N mode - RPMs are 1100-1200, then click back to Normal mode and RPMs are droping to under 1000 - something like 900+. Click N again - back to normal 1100+. It looks like Normal mode is closing the valve and choking the engine.
Just check how the exhaust valve behaves.
If you put the car in reverse, it should fully open the valve. If it doesn't, then they either put the spring in a wrong way (yes, that is possible) or the spring is already broken (likelihood of this happening increases the stiffer the spring is)
So - reverse gear on any drive mode or N mode and then reverse to see the flap fully open ?
And yeah - there is a possibility that spring was mounted by them wrong (but I asked this technican did he done this before) or it is a bit to low compared to OEM.
I will check the flap on friday using my inspection camera and I ordered small wheel ramps to check the box by myself too because I didn't want to do it before blindly (car is too low and I don't have tunnel under the car in the garage).
And I forgot about one thing - old OEM exhaust spring part number was 287A6S0100 but I found that hyundai did somekind of upgrade and now I can found 287A6-IB100-FFF - there is info that this one is reinforced after problems with older one.
New spring is about 10-20x cheaper !! But there is one problem - I found this spring only in USA and Canada.
Price is about 3-5$ depend on hyundai dealer shop (they are official oem parts).
I tried to order them directly or from amazon/ebay but they don't send to Europe.
Most funny is - spring price 4$ and shiping from US almost 100$........I need to ask my dealer....
About OEM springs:
1- first OEM spring - 287A6S0100 - can't order it from hyundai service - it is replacement part only on warranty
2- new OEM spring - 287A6-IB100-FFF - upgraded one - only in US/Canada - big problems with order (tax/shipment)
Ok guys - here I am again.
I found problem and solution. And NEW problem....
First of all - I ordered new springs from USA - two pieces from Whoosh Motorsport.
Here is their picture:
Blue is improved and red is improved, thicker and HD (heavy duty 10% harder - 3y warranty).
I used blue because red is too thick ( I found one guy on internet that say about this problem - this spring is too thick from flap side - from plastic motor side is ok). I didn't want to try it for all cost.
Here is spring comparision - Woosh red (US) - ASR (DE) - OEM (hyundai):
Next step was to raise rear of the car using my new car ramps:
So.......I got under the car and saw.....that one of three exhaust control actuator plastic mountings was broken.
Plastic box controlig the flap held only on two screws and when I tried to squeeze it - it moves about 1cm up and down because of lack of this screw.
Sooooo.... I did this and go to hyundai service like that....
After long talk I'm still waiting for their answer what to do with this problem because they unscrew the box, changed the sprig and screw it again few days ago so......
In the meantime I drove to shop with metal parts and did some myself repair. Got again under the car and do this:
If the name in english is correct is is - metal worm puller - and on the plastic box some felt pads to not too over tight the exhaust control actuator.
I did some tests of the exhaust and everything is way better than it was.
I put the inspection camera inside the exhaust pipe next to the flap.
When car is off - flap is fully opened. Starting the car - flap is fully closed. N mode or reverse gear - flap is half opened.
After incrasing engine RPMs - flap is fully opening and half closing after RPMs are decrasing.
Now I can hear again in my garage, when I'm starting the cold car, press N and it is immediately louder.
Pops and bangs are there, popcorn too and loud shots too. When car run in idle for example in front of the garage - there are no metallic weird sound from the exhaust flap side.
For now - car is working fine - not counting the broken plastic holder....
Reactions: Jajodu and p_b82
