Trackday question: Stability-/traction control
Mightymoo
644
1,191
Norway
I am wondering what you recommend: Stability-/traction control set to «Sport» or «Off»?
Have some experience on track in other cars.
During first session of day or during first lap(s) keep it ON (Sport) if you are not experienced track driver. I will recomend it because your brakes and tires are cold and you might be surprised if you will loose rear end of your car during braking in to the corner (steering wheel is turned direction of apex).
Our cars have less weight on rear and if you are braking hard and turning on to the corner same time, your car will oversteer when tires does not have optimal temp for track. But if you are experienced track driver - turn it OFF, heat up tires as quick as possible and enjoy ;)
Do not also forget to take care of your tire pressures.
Do you want to / can you afford to turn your car the right way up after visiting the kitty litter!
Start with it on and build speed, ability, understanding of the car. As above!
I kept mine on and loved it, car is more capable than me all day long. Cornering speed and grip out of the apex in unreal.
Reactions: Mightymoo
