Suspension and Chassis Hyundai Front Strut Tower Brace
Maverick
2,175
3,289
Bummer - at the bottom it says"Dieser Artikel ist zur Zeit nicht verfügbar! Voraussichtles Lieferdatum ist der 01.09" or for the rest of us, "This item is currently not available. Projected delivery date is 1 September" I put it on my shopping list (when someone asks if I have any wishes)
I am a bit skeptical about this to be fair..
They spent quite a large percentage of their budget on the chassis, engine, gearbox, basically the crucial parts that make a hatch hot, to begin with, and that's perfect.
In every test video and review, that's what get the most praise, how stiff and non-flexy the chassis is, how well it attacks corners, etc.
As I can't contribute from experience on this matter (my Naughty hasn't even entered the production line yet), what are you thoughts on this? Will a strut bar and/or anti-roll bar make a noticable difference on a everyday basis? Such a difference to justify the price? :rolleyes:
I'm not a track person nor do I have the experience, but if someone is looking for a gift for me...
I don't think I would say, 'Oh, you really shouldn't have - I don't need that.' -- but I might reply with, 'Is installation included?'
I hate to know that there is so much what you can apply to your car. I wanna buy things day for day :D talked with 2 n owners and they said you can't feel the difference in all day use. Maybe you feel it a bit on the track, but that also could be placebo :/ I like the stiff bar in the back, it looks sporty and that's why I'll buy one soon..
Reactions: Maverick
Probably not a lot of difference to the every day drive.
But I bet it looks cool :cool:
I'll be topping up my washer fluid every weekend.
I mean.. I guess it would make some sense on a normal i30..
Maybe it would make it a bit more agile and add a bit of sportiness to it, but on a car like N, it doesn't make much sense, does it?
I am also like you @padigree, I see all the new N stuff every week and I just wanna buy everything, but then my sensible side kicks in and I take the cursor away from the ORDER ME NOW button. :oops:
It's ok to buy 25€ N stickers, and 25€ LED's and so on, and very different to start dropping 500's and 1000's on a car.. more when it doesn't make sense. :rolleyes:
Think the anti-roll bar may make a little difference, depending on the size of the stock unit vs what they are offering. From my experience when i had anti-roll bars installed on my wrx it transformed the car, but they are a bit more prone to understeer. Installed 24mm adjustable (stock is like 19-20mm) and car felt alot more eager to rotate/turn in.
Reactions: Maverick
Yes but people still go out and modify their cars :) Are you going to keep buying the pirellis they came with or go to other brands ?
Some people have even decided to put on 18" wheels instead the 19" wheels. It just depends whether YOU want to or not.
Also the car is not perfect, there is no such thing in engineering.
This item is a strut brace between the tops of the front suspension towers. What the OP refers to as the rear anti-roll bar, I believe, is the strut brace in the boot.
Roll bar, anti-sway bar, sway bar, stabilizer bar: It helps reduce the body roll of a vehicle during fast cornering or over road irregularities. It connects opposite (left/right) wheels together through short lever arms linked by a torsion spring. A sway bar increases the suspension's roll stiffness, its resistance to roll in turns, independent of its spring rate in the vertical direction. Basic concept:
This is Hyundai's "rear stiffness bar" in the boot:
And this is the strut brace (strut bar, or strut tower brace (STB) in the engine compartment. A suspension accessory usually used in conjunction with MacPherson struts on monocoque or unibody chassis to provide extra stiffness between the strut towers. Example:
A strut brace ... is now available to go along with the rear anti-roll bar.
Not sure how a strut brace goes with the rear antiroll bar. Surely front and rear antiroll bars go along with each other as do the front and rear strut braces. No worries.
It was meant as an accessory being available for purchase, not as parts being installed together. Or are you just being sarcastic, making fun of my English? I deleted it to avoid any misunderstanding if that was your point.
