Oil pump - Red oil light came on!
Vermaak
12
Eastbourne
I thought I would share my experience of an oil pump failure with you guys, as it might help one of you in the future and save you about £2,000.
I was driving home in December, and the red oil light came on when I pulled into the services on the M1. Long story short. We got the car back, and after a full check, we found that the oil pump had no pressure.
The spring for the pressure relief valve in the pump had snapped. Below is the pump and the snapped spring. So the problem had been found, but next came the hunt for a replacement pump. What I didn't realise was that, as you can see from the photo below, the pump comes attached to the balance shaft assembly. This makes it (in the UK and apparently Europe) an expensive part to buy and one you can only buy as an OEM part.
We contacted Hyundai UK and found that they have only one of these at the moment in the UK, and it would cost £2,337. Now, I'm not one to cheap out on parts, but this seemed on the expensive side, and my mechanic was not having it, so he started digging around. He then found that this exact part (minus a zero on the part number) is on many cars like the Santa Fe, Sonata, Optima, and Sorento. We found a seller on eBay in South Korea selling new OEM parts, and the pictures matched mine exactly. The best bit is that it is currently £286.62 including shipping to the UK. Once ordered, it said it would take a month to get here, but it actually took six days, which was quicker than it took Hyundai UK to send over some new bolts and gaskets for the car. I paid just under £100 for import duty and tax. I've included a picture of the part number sticker on the box for reference.
My mechanic has done a thorough check over the original and the new part and confirmed they are exactly the same. We are just waiting for one more gasket, then the car is going for a test drive before I collect it later next week.
I almost bought one for sale in the UK from a breaker, but we noticed that the breaker had removed not only the black bolts holding the pump assembly to the bottom of the engine but also the bolts holding the whole assembly together. This could have come apart in shipping, and they don't sell the bolts separately, so we didn't want to risk using that one, plus the new part from Korea was cheaper.
If anyone has a failed pump, I hope this post helps you save a decent amount. Still no idea why the UK part is so damn expensive when it's relatively common and cheap to buy in Korea.
That's a great find!
The small voice says to me "why is the part number different if it is the same model" perhaps it is an oversight on the parts catalogue but perhaps there's something "beefier" on the N model's pump.
Reactions: Vermaak
He said it was just a single zero. He's had them side by side and measured them. The only difference is a small lip around the outside of the oil pickup where it's pressed together, but there is no difference to the actual inlet with the gauze. Nothing that would affect the flow of oil. The bolt pattern, dimensions, drive cog, and weights on the balance shafts are the same.
Looking at the part, it covers everything from 1.6-litre petrol engines all the way up to 3.5-litre AWD and also some diesel engines in their range. The listing had it compatible with 399 variants of different models. Looks like they used an off-the-shelf part during development and stuck with it, which is very common.
I'm the test mule for this, and if anything isn't right, I'll report back, but he said it's the same part, and I fully trust him. I would usually use a local garage, but he's a good friend, and it's a 45-minute drive from where I live, but I wanted him to do this repair. He knows his stuff. His project car is a Lupo with a Golf GTI engine in it (can't wait for it to be finished), and the work he's done fitting it in is astonishing.
Reactions: Animatt and p_b82
Maybe worth badgering Hyundai to see if they can get/share some tech spec's to explain it too?
perhaps there's something inside that's been tweaked /changed and it can't be seen externally - maybe it's a % factor for covering the track usage scenario and in 99% the time it's not an issue.
the lip seems to imply that there might be some leaking issues (popping a slight lip on an air or water hose makes it a better seal - I know from personal experience with a modded car) - so might be something to do with the lower oil viscosity we run on the N vs "mundane" engines.
I've not got far with Hyundai yet but I might push them further on it. The new one has a bigger lip on the outside of the pickup not the opening where the gauze is. He said it looks a little more substantial that the old one on my car but nothing that would effect the flow through the pickup. Picture below for reference.
Can't you just replace the pressure relief spring?
You could try but we couldn’t find the spec of the spring and Hyundai don’t sell it separately. Also there are no details for the torque settings for the bolts holding the part together. As it fully balanced I would hate to get it out of sync as well.
Ive been driving the car all weekend as everything is back up and running and everything seems really good. Pressure is good and the car runs as smoothly as it did before, at first I thought it was better but I’ve been driving a diesel van for over a month so figured it was just that.
Can you share the part number at all? I have had mine serviced at a main dealer and a month later my oil light appeared at warm idol and I've spent over £600 in labour to find the issue is the oil pump which I refuse to pay over 2 grand for!
Cheers mate.
I've just realised the number is there already!
Reactions: Vermaak
I hope you get it sorted. I’ve just driven it to the Netherlands today from the UK and will head down to the Nurburgring this weekend to watch a race. No problems at all since having it fitted. Just find a decent garage to do the work.
Reactions: ADSYi30N
I've sourced one from ebay, coming from Korea. Glad you have the issue sorted hopefully mine gets sorted too! I work in the motorway trade so can ask the lads in the workshop to help me out!
Reactions: Vermaak
Perfect. You’ll probably have to pay import duty. I did on mine but it was still so much cheaper. It’s the labour that was the biggest cost. I hope it gets sorted.
An expensive solution for a broken spring. I reckon you could work out the spring rate via the diameter of the coils.
