Suspension and Chassis Front Wheel bearing
Laser30n
139
47
hey guys,
had anyone ever problems with the front wheel hub bearings (i30 FL from 24)?
My bearing sounds bruming after 40t km.....
Anyway the warranty should cover the damage.
should fit, right?
Did anyone this repair by his own?
Should be possible.....i guess
Try bilstein parts finder, get the part number and do a search on it. I usually use parts in motion..
Next day delivery and febi parts are OEM quality. Looks easy enough to replace.
in the meantime both front wheel bearing are damaged according to a other dealership.
both will be replaced under warranty.
hopefully hyundai is not claiming this case within the 3 months range....
