Engine Temperature on hot days
Klunk
6
Melbourne
Normally my I20N engine temperature is around 100°C, but the other day the outside temperature was 38°C and the engine temperature sat on 85-86°C for an extended drive, the next day at 35°C outside temperature, the engine temperature was at 100°C again.
Does anyone know the reason for this?
That's the coolant temperature, more revs, the faster the waterpump spins. More speed more airflow for the cooler, also the thermostat is regulating.
Yes I understand it is the coolant temperature, but it is normally controlled at around 100°C, but on a hot day (i.e. 38°C it was controlled at around 85°C, this is repeatable and only when the outside air temperature is very high. I thought that maybe this has been designed to control the block temperature as less heat is expelled directly by the surface of the block. The oil temperature was also in the 80s. To me it looks like a programmed design feature, as it is so different from the normal coolant temperature and so constant .Or it could be to offset some of the performance impact of warmer intake air.
Hmm, maybe the thermostat is electronically controlled via IAT sensor, and it opens more. Additionally could be immense ignition retard.
The engine performance didn't feel any different to normal, so I don't think ingnition timing was changed. I expect the coolant temperature is controlled by the ECU and this is by design. I just wondered if anyone else had noticed this or knew the reason. I know that if driven very hard the boost pressure is managed to control the coolant temperature, but this is only when the coolant is around 120° as I understand.
Perhaps it is done so the raditor doesn't heat up the intercooler too much, to control the charge air temperature?
The car was delivered September 23 and has all current updates afaik.
Ok, this seems to be a normal function in extremely hot weather.
Yesterday, where I am in South-east Queensland, the outside temperature was 38-40. My car, which had always run at ~99c, was heating up to that and then suddenly rapidly dropping to exactly 86c. If I stopped and restarted it would go through the same cycle.
I was concerned about it at first, but then I thought maybe it's something Hyundai have done to help protect at least this particular vehicle in extremely hot weather. It just seemed too consistent and coincidental with the hot ambient temps. If so, there must be some means to allow increased coolant flow under those conditions.
Today the temp is 30-32c and lo, and behold, the car is back to running at 99-100c under normal driving conditions, so it would appear this is indeed what is happening. Finding this thread where someone experienced identical behaviour under exactly the same conditions also makes it seem to be by design.
I did consult the manual but I couldn't find any mention of running temps being lower during extreme heat. I may have missed something but you'd think Hyundai would put it in there. Maybe I'll try and get an answer from them.
Reactions: tacthecat
This post is a bit older, but I can also provide some feedback on this.
Normally, based on my daily driving habits, my engine temperature is around 100–102 degrees. In the summer—though only on some days—I’ve also noticed that the temperature (of the oil and engine) is lower than usual.
Yesterday, it was 37–38 degrees in Germany. Even though I was driving at a brisk pace, my engine temperature was 86–87 degrees. This morning, at about 20 degrees, everything was back to normal (about 101 degrees).
Since this low reading is so rare—even though I vaguely recall having experienced something like this 2–3 times in recent years—I went straight to the forum and searched for similar reports.
So, I can confirm that at very high temperatures, the engine cooling behaves differently and the temperature is lower than one would expect.
Thermal heat management for both oil and water is excellent in the i30N/EN vehicles. Track or spirited driving will raise the numbers but not to an overheating level.
Same with my I20n few days ago.
Outside temp about 38°C and coolant temp drop from usual 99-105 suddenly to 86.
Today it's colder outside, about 22°C and temp run normal from cold to 100 and then drop again to 92.
I will check next days because it's the first time in summer which does that.
Another photo from today, max was 100° min 86
Update: everything was normal today. Coolant temp reached about 100° and kept.
I'm taking the car to the mechanic tomorrow to have it checked for any problems. It's under warranty.
Reactions: Namyang
Replying to myself, official dealer said that temp control module must be changed.
As a result, I'll be without the N from Wednesday until next week.
Why?
Did you compare under same load/power demand conditions?
The Thermostat is electronically controlled by torque or power demand.
So under same demand it should drop to quite similar temperature if the cooling system is able to do so (similar outside temperature and similar vehicle speed=air volume flow)
Why?
Yes different days, but same kilometres, hot and cold weather (about 10-15°C difference).
Dealer said that a temp module have to be changed. Car is under guarantee so that's fine.
Hi,
Sorry but I don't understand what you mean.
Don't understand the problem which you try to describe.
And a dealer with any opinion is not a reason for changing anything without understood misbehaviour or logged dtc.
Reactions: Namyang
Hi,
With dealer I refer to the mechanic. Some test was made with proper diagnostic tools and finally got this solution, a temp reading module and cooling circuit dialysis and everything is fine.
Maybe there is an ECU unit or in the main ECU included with a map for cooling, which regulates the thermostat if it is really a electrical controlled one.
Reactions: JundaiShur
