Hello,
I'm Patrice and I've been driving an i30n Performance for 2 years. My problem since I have the car is already relatively dangerous and the Hyundai workshops do not want to look.
My problem:
At the first stronger acceleration after starting the engine (cold and warm) suddenly my car steers to the right. I have to steer the steering wheel about 20-40 degrees to the left. It's like a third hand is pulling at the steering wheel. The condition remains active when accelerating, braking or coasting. After 1-3 seconds it disappears again relatively quickly. As if the power was gone under one second. Once that happens, it doesn't come back unless I turn the car off and on again.
I drive around with the standard Pirelli P Zero tires with 19 inch rim. The problem is almost gone when I take my 18 inch winter tires.
Ruts, tires, etc I can rule out.
I would like to ask you if you know the problem or theoretically have an idea.
I am open to anything, as it is already very dangerous.
The car had also already received the first 30,000 km maintenance. There I have addressed the issue but was stamped for an idot and said that would then be ruts.
I look forward to your answers.
Greetings
Patrice
My problem:
Greetings
Patrice
