veloster N - turbo intake charge pipe spec
veloter N 275ps engine
oem reducer pipe
width : 29~30mm
in : 56~57mm
outside : 63mm
i will change my intake made it aluminium 90mm pipe + 63mm>90mm reducer silicone pipe
and using Bmc ota air filter
this is aftermarket intake pipe 76mm for open airfilter ( can not use oem air filter box )
made by SuperDrift company ( south korea )
Cygnus X-1
Thanks for the measurements. Pics of everything installed would be nice. Correction about the power number... It’s 275 PS, not HP, which would be 271.
#5
Have you felt a big difference in power with this mod installed ? And how’s it sound ? Does it sound like a jet engine when on throttle like the VT ?
I am currently in the conceptualization because it is not a general shape intake pipe. The sound differs according to the appearance of the intake pipe and the intake filter. However, the filter of the bellows n and i30n is an open filter shape, In fact, the big impact does not make much difference, but it will definitely make a difference in the response temperature and the intake temperature
i send to picture it is comming soon on south korea
2019...jan~mar
oem reducer pipe
width : 29~30mm
in : 56~57mm
outside : 63mm
This is great info, thank you! I'm in the process of making my own custom intake currently as well and this saves me a lot of work!
I'll post pics once I'm finished mine too. I'm planning to incorporate the stock airbox to eliminate as much heatsoak/intake of hot air from the engine bay as possible and have a cleaner install. I may try to modify it a bit for better airflow however, I'll have to see what improvements can be made.
