Brakes Veloster N Brake Tuning
jeroenvde
861
860
Belgium
So the calipers mount directly on the Hyundai hubs without an adapter plate?
And what discs are those? CTS-V are 5x120 bolt pattern, so they will not fit our Hyundai's
KoreaBroa
32
46
South Korea
It's a 4piston and need a separate additional plates , it's common in Korea, and discs are used korea product.
in korea old cts-v 4piston caliper is popular item, so there are many products related to it.
Y0UKN0WITSCHRIS
1,058
1,023
Okay, thank you for the clarification.
However things are still quite vague :p
The ctsv brake swap in common in the US as Korea. A lot of the guys who track and autocross the VT do the big brake swap. And I believe pierce motorsports over here in the states sells a complete kit for the swap. But it’s based on the VT.
Reactions: jeroenvde
1FastStagea
493
765
Canada
I don't really think it's necessary to upgrade the calipers on these cars at these conservative power levels. Once you start going above 400whp, I think then it would be warranted but the Ns have fantastic brake setups out of the box. A simple set of track pads, some high-quality blank or slotted rotors, and some stainless steel braided brake lines should be enough for pretty much everyone. Not to mention parts cost and availability are also great since it's all OEM stuff (no brembos, which have significantly higher costs for pads and rotors).
Now if you just wanted to upgrade them for show, that's a different story :p
Cygnus X-1
1,172
1,546
US
I’m actually going to look for a slightly smaller GM/Brembo combo so I can fit 16” wheels on. Don’t think they’ll fit with the current front caliper/rotor dimensions. Don’t want any weight gain and hoping for weight reduction as a result.
