USB Hub
thunder
69
33
Yes, you can but if you use Google Auto and usb music from a stick in your hub, the phone doesnt charge the battery.
Regards
Reactions: rhodzy
pugdog
15
20
Australia
I've tried a 4 port hub before and it hasn't worked :( I want to be able to listen to my music from a usb stick and also use Android Auto at the same time.
padigree
Apr 1, 2018
1,682
2,845
www.youtube.com
Thats not possible. You can listen to music and charge a phone. But thats not because of the Hub, Thats because of the radios firm-/ software.
pugdog
15
20
Australia
Thought that may be the case, just some wishful thinking. It's annoying not to be able to listen to usb music and use Google map on the system.
pugdog
15
20
Australia
Since you have already your phone connected, why not just dump your audio files on your phone?
Most of the time I only need to listen to music without needing to use google map, but mainly it's a pain having to plug and unplug the phone whenever you get in and out of the car (which also includes opening and closing the music app)
asd
949
1,048
36
Poznań, Poland
Or making Apple Car Play / Android Auto available by bluetooth / wlan. Then there would also be a sense for the Qi induction charging station:rolleyes:
I am not sure that Bluetooth, even 5.0 has sufficient bandwidth ACP/AA...
As mentioned elsewhere - AA has plans for future wireless support, question is, will it be possible with a software/fimware upgrade to make i30N unit compatible.
I would not mind having 2 usb ports, maybe one with higher power output, so you don't need a 12 v usb charger to actually charge a device reasonably fast.
Tim96
There is wireless CarPlay already in the new bmw models, so it’s not a problem with bandwidth but more with power, so you have to plug in your phone eitherway.
