Technical Specifications:
Brand: Hyundai
Model: Kona
Generation: Kona N
Modification (Engine): N 2.0 T-GDI (280 PS) FWD
Doors: 5
Seats: 5
Coupe type: SUV
Power: 280 PS/ 5500-6000 rpm.
Maximum speed: 240 km/h
Acceleration (0-100 km/h): 6.4 sec (5.5 sec Launch Control)
Year of production: 2021 - .
Color availability:
Ignite Flame/Red (MFR)
Atlas White (SAW)
Performance Blue (XFB Solid)
Sonic Blue (PYU)
Cyber Grey (C5G)
Ecotronic Grey (EDIT)
Abyss Black (A2B)
Phantom Black (UK)(PAE)
Dark Knight Pearl (YG7) (disc.)
Red lower trim color code:
Passion Red (NRR)
Length: 4215 mm
Width: 1800 mm
Width with mirrors: (EDIT)
Height: 1560 mm
Weight: 1,510 - 1,569 kg (full tank, 75 kg driver)
Wheelbase: 2600 mm
Front track: 1579 mm
Rear track: 1575 mm
Ride height: 173 mm
Min/Max volume of Luggage in trunk: 361 L / 1143 L
Head room front/rear: 1,005 mm (965 mm with sunroof) / 961 mm
Leg room front/rear: 1,054 mm / 893 mm
Shoulder room front/rear: 1,409 mm / 1,385 mm
Model Engine: THETA II series GDI
Engine construction: aluminum block & head
Position of engine: Front, transversely
Engine displacement: 1998 cm3
Charge system FL: Twin-Scroll Turbo 1.2 bar (MHI (EDIT))
Torque: 392 Nm 2100 - 4700 rpm.
Power-to-weight ratio: (EDIT)
Weight-to-power ratio : (EDIT)
Valvetrain: DOHC, E-CVVT
Position of cylinders: Inline
Number of cylinders: 4
Firing order: 1-3-4-2
Cylinder Bore: 86 mm.
Piston Stroke: 86 mm.
Crankshaft bearings: 5
Compression ratio: 9.5
Number of valves/cylinder: 4
Battery capacity (Ah): 70
Fuel System: Direct injection
Fuel Type: Petrol (Gasoline)
Fuel tank volume: 50 L
VED band (UK): K
CO2 Effizienz (DE): F
CO2-Emission: 194 g/km
Emission standard: Euro 6d-Temp-EVAP
Drag coefficient: (EDIT)
Noise levels:
Stationary: 92 dB(A)
Driving: 71 dB(A)
Front suspension: Independent type McPherson
Rear suspension: Multi-link independent
Brake system: Dual-diagonal, split circuit, power assisted with Electronic Brakeforce Distribution (EBD) and Brake Assist System (BAS)
Front brakes: Ventilated discs
Front brake diameter: 360 mm x 30 mm
Rear brakes: Ventilated discs
Rear brake diameter: 314 mm x 20 mm
Steering type: Steering rack
Power steering: Electric Steering R-MDPS
Minimum turning circle (turning diameter): 12.5 m
Number of steering wheel turns lock to lock: 2.14
Differential (front): Electronically controlled mechanical Limited Slip Differential (E-LSD)
Payload: 441 - 500 kg
Max tow weight braked/unbraked: ~1,600 / 700 kg
Wheel Alignment / Geometry (EDIT)
