Status
Not open for further replies.
Maverick
1,786
2,786
Europe
Brand: Hyundai
Model: i20 3rd gen
Modification (Engine): N 1.6 T-GDi
Doors: 5
Seats: 5
Coupe type: Hatchback
Power: 204 PS/ 5500-6000 rpm.
Maximum speed: 230 km/h
Acceleration (0-100 km/h): 6.2sec
Year of production: Q3 2021 - .
Color availability:
Sleek Silver (SLS)
Atlas White (SAW)
Performance Blue (XFB)
Brass (R3W)
Phantom Black (PAE)
Dragon Red (WR7)
Intense Blue (YP5)
Length: 4075 mm
Width: 1775 mm
Width with mirrors: 2045 mm
Height: 1440 mm
Weight: 1220 kg (full tank, 75 kg driver)
Wheelbase: 2580 mm.
Front track: 1544 mm
Rear track: 1542 mm
Ride height: 130 mm
Min/Max volume of Luggage in trunk: 395 L / 1165 L
Head room front/rear: 985mm / 960mm
Leg room front/rear: 1072 mm / 882 mm
Shoulder room front/rear: 1395 mm / 1390 mm
Model Engine: GAMMA-II 1.6
Engine construction: aluminium block & head
Position of engine: Front, transversely
Engine displacement: 1598 cm3
Charge system FL: Twin-Scroll Turbo 1.2 bar
Torque: 275 Nm 1750 - 4500 rpm (Overboost: 304 Nm @ 2,000 - 4,000 RPM)
Power-to-weight ratio: 134.5 watt/kg
Weight-to-power ratio: 7.4 kg/kW / 5.5 kg/PS
Valvetrain: DOHC, D-CVVT
Position of cylinders: Inline
Number of cylinders: 4
Firing order: 1-3-4-2
Cylinder Bore: 75.6 mm.
Piston Stroke: 89 mm.
Crankshaft bearings: 5
Compression ratio: 10:1
Number of valves/cylinder: 4
Battery capacity (Ah): 60
Fuel System: Direct injection
Fuel Type: Petrol (Gasoline)
Fuel tank volume: 40 L
VED band (UK): ???
CO2 Effizienz (DE): F
Emission standard: Euro 6d-Temp-EVAP
Drag coefficient: 0.32
Noise levels:
Stationary
: 94 dB(A)
Driving: 67 dB(A)
Front suspension: MacPherson strut
Rear suspension: Coupled Torsion Beam Axle
Brake system: Dual-diagonal, split circuit, power assisted with Electronic Brakeforce Distribution (EBD) and Brake Assist System (BAS)
Front brakes: Ventilated discs
Front brake diameter: 320 mm x 28 mm
Rear brakes: Ventilated discs
Rear brake diameter: 262 mm x 10 mm
Steering type: Steering rack
Power steering: Electric Steering R-MDPS
Minimum turning circle (turning diameter): 10.54 m
Number of steering wheel turns lock to lock: 2.16
Differential (front): Mechanical Limited Slip Differential (m-LSD)
Front seat weight: ??
Rear seat weight: ??
Wheel Alignment / Geometry ???
Engine compartment fuse panel
Status
