TarmoT 385bhp/526Nm i30ntracktoy - SOLD
TarmoT
1,052
2,889
Poland
Lets start from beggining:
I bought my car last year in June. There was a long storry behind that but shortly I made order for white car in Feb 2018 but because of production delay, I managed to end with Performance blue non GPF car.
TarmoT
1,052
2,889
Poland
Last year I managed to make 6000km and change the oil 2 times - on 1000km and on 6000km:
For street use I bought 8J x 18" ET45 Sparco Assetto Garas and 235/40 R18 Michelin Cup2-s:
Also lightweight wheel nuts:
H&R springs:
Wiechers strut bar:
Some blue inserts to the interior:
TarmoT
1,052
2,889
Poland
Couple of weeks after I bought my car, it went to the RCP exhaust workshop. They made me 3" downpipe with 200 cpsi cat, non resonated middle section and custom black tips for rear box:
All that started to sound like this:
One more picture from street wheels and H&R springs:
TarmoT
1,052
2,889
Poland
Meanwhile we made couple of dyno runs:
100% stock car:
With intake and exhaust:
I also tried that box:
And dyno results in sport mode:
And in Race mode:
Because I did not like how car act with RaceChip box, I removed it and tried to remap my ECU. The best result what my international remaping experience gave me was not good:
So I finished my last season with stock ECU program.
loafer-N77
Feb 4, 2019
1,192
1,484
Sorry if i've missed it somewhere else but why did you not like the car with the Racechip?
TarmoT
1,052
2,889
Poland
Next steps where taken only for making car better on track:
Some weight loss (around - 48kg) Mirco ST + custom alu frames:
Armed brake lines + Motul fluid:
8J x 18" ET50 Autec Wizards + 245/40 R18 Federal FZ-201 tyres:
Some thermal wrapping:
And some action:
TarmoT
1,052
2,889
Poland
And now about my plans for this season. Season starts on 05.04 but I have so much things to do that Im not sure that I will manage.
I left my car to RCP exhaust workshop again in January and will pick it up today - yes it took long and it is the reason why time is not my friend anymore :(
So, what has been done by RCP?
New catless downpipe (starts as a 3,5" from turbo and will finish as a 3" before flex section):
Flex section:
After flex section, my new exhaust will continue with 2,75" pipe untill resonator (because of noise restrictions of tracks), after resonator it will continue as 2,75" untill custom built rear muffler. Rear muffler has aftermarket flap what is pluged to OEM connector. It means that exhaust flap will be still controlled by car ECU. End tips are 114mm and black.
I hope that soon I can add additional photos and video.
TarmoT
1,052
2,889
Poland
Under bonnet there will be also some mods done.
I must install my Turbosmart BOV:
Wagner Tuning intercooler:
Test InJen short ram intake I received for testing:
Install new design and reinforced induction snorkel:
I will rebuild that InJen intake system by using hard pipe only from that system. I will cut it shorter and use that boy:
TarmoT
1,052
2,889
Poland
Suspension and transmisson system:
ST XTA coilover set:
KW el. dampers emulators:
Eibach rear adjustable ARB:
Powerflex black bushing for transmission mount:
NRC Nolimit Racing Clutches Stage1 kit (disc, basket and release bearing 650Nm) powered by Abgastechnik Hiller:
After installing new suspension, I will corner balancing my car and make new allignment for track:
-2,75-degrees of camber in front, -1,75-degrees of camber in rear, littlebit of negative toe in front and rear + as much caster as possible.
TarmoT
1,052
2,889
Poland
Exterior of car:
2 x 8J x 18" ET35 + 2 x 8J x 18" ET38 Fondmetal 9RR lightweight wheels (8,65kg per wheel):
235/40 R18 Extreme VR2 semi slick tyres (2 x medium R5 + 2 x hard R7):
Full aero kit for track built by Time Attack Customs - some examples of their work:
If they will manage, there will be 2 bonnet vents also installed:
