Suspension and Chassis ST suspensions spacers
fire3
20
12
Slovenia
So for christmas i've bought my GF a set of spacers for here i30n. Since it's for the winter OEM rims i've decided to go for the 12,5mm per side spacers from ST suspensions. I've checked on a few sites that they should fit with the shaft nuts from ST. So i bought the whole set. But as you can see from the pics it doesn't fit since the shaft nut has a diameter of 15mm and the holes on the OEM rims is 13.7mm.
I've fixed the problem with drilling machine and a 15.7mm drill.
Just wanted to let you all know if anybody is thinking of buying them. ;)
Reactions: Jajodu and PeterP
