Should I be worried about this? White residue in exhaust tip
Dimi_dboe
20
30
Florida
Hello everyone I am not really that mechanically inclined but I was looking over my car as I do every day before I go to work. I noticed in the exhaust tip that there was some white specks or dots don’t know what causes them. Also should my exhaust tip look that dark?
I read online something about the engine maybe running lean but I have no error codes.
My car is VN/PP
Fuel: 93 octane since I got it
Mileage: 7k
The mods I’ve done is Velossa ram air, takeda intake, forge turbo inlet adapter.
here’s a picture for a little bit of reference. I have no idea what it is and should I be worried my pipe looks this dirty?
3,750
It's water condensation that has mineralized from the exhaust. Taking in considering your humidity, you'll have more condensation in the exhaust. You can see the black carbon soot at the bottom. The car is set up to run rich. Never attempt to determine the car is running lean from the exhaust outlet. The proper way it to do a spark plug chop test.
OEM ECU mapping will compensate for more than what you have installed. You're fine and have nothing to worry about. :)
watto33
Jan 30, 2019
129
103
Brisbane
I thought this too. Until I installed the IFX intake and engine started to misfire and ping at low revs. :rolleyes:
3,750
I'm not so sure why it would, the ECU can easily compensate for the intake. Pinging comes from to low a fuel octane generally. Misfires come from loaded up plugs or faulty coil pack/s. Did you reinstall the OEM intake and check if there was an pre existing issue?
Also , check to make sure you don't have a vacuum hose leak or a hose that is not properly seated. :)
