Drag to reposition cover
NULLOBANDITO's Fastback N
NULLOBANDITO
1,681
2,289
Innsbruck, Austria
Readjusted the shifter cables again today, shifts are better and the gearbox now recognizes the selected gear accurately for the rev-matching.
Also: when ripping through the gears it sounds like a really aggressive DCT, funnily enough. No need to wait for the DCT version for the sound.
Reactions: r_anderson96
r_anderson96
448
525
Glasgow
Need to get my finger out and do the same to mine๐Ÿ˜‚
  • Haha
NULLOBANDITO
1,681
2,289
Innsbruck, Austria
Mirror covers arrived and don't fit (thanks Hyundai for making PD and PDe not interchangable)... ๐Ÿ™
While disassembling and fitting, quite a few clips on my original mirror covers and the CF ones broke off; only the OEM ones barely hold on right now, so I gotta get a new driver's side one.
However the passenger side CF cover is still fine so I went ahead and ordered Elantra GT mirrors (hopefully the right ones) from the US to try and see if they work with the i30N.
UPDATE: Said screw it and ordered everything again - both mirrors and the CF covers. Let's hope it works out this time.
NULLOBANDITO
1,681
2,289
Innsbruck, Austria
@NULLOBANDITO
Do you have some kind of a tutorial on how to remove the mirror covers and what do you mean by Glue it in?
Basically you use a trim tool to carefully pry open the cover on the inside and then try and pull it off, there's a lot of clips in there.
And by glue I mean the same glue used to fix windscreens into place.
