N-light seat rattle
5,053
Check the seat latching for the seat back. Make sure it not loose fitting on the latch.
I suspect your talking specifically about the passenger seat when not in use?
CozyTony
26
25
Finland
I’ve made the same observation on my19. Some rattle coming from the passenger seat area. Passenger or no passenger, the sound occurs, but not always. Only when moving, not stand still.
I need to listen to it some more. Today I figured to put some bass heavier music - rattle starts from the same area, nowhere else to be heard. When I remember I’ll try to put music and try some panels if I could locate the rattle.
Hope you fix yours.
Pastiche
176
170
Spain
Perhaps the noise you mention comes from the seatbelt height adjuster.
When driving on very rough roads, there is sometimes a rattling noise. It is usually heard on the driver's or front passenger's side, although I have had it happen on both sides. If I touch the belt adjustment lever button, the rattling disappears.
In the pre FL it already happened to me.
Apologies if I have not used the correct English terms.
