I’m thinking the same tbh, was going to go 19x8.5 but I’d rather stay closer to the factory offset.
I think you mean 225/40.Looks like I will go for the bronze ones in 8x18 ET50 with 235/40 on my shadow grey hatch in spring.
8x19 and 8.5x19 are only available with offset 45.I’m thinking the same tbh, was going to go 19x8.5 but I’d rather stay closer to the factory offset.
Nope. Handling is even better cause of the weight (around 4kg less with 8.5x19) of the Motec.Any disadvantages to that offset? Read that the deviation from stock should be kept within 10%. Has your handling been affected?
Handling is indeed allot better, you really feel the difference!Nope. Handling is even better cause of the weight (around 4kg less with 8.5x19) of the Motec.
The 8x19 are new. Motec started to produce them a few months ago.
If I had the choice I would go for 8x19 for now. With the 8.5x19 on the stock Pirelli PZero you have a lot of stretch cause the PZero has the width of a 215-225 tire. And if you also want to add springs then it's definitely better to go for 8x19.
I have H&R springs. So lowered 35mm.Cheers, is yours standard ride height? Looks a bit lower than stock, that or the extra width makes them look more flush. 19x8 is probably a good shout then. Plus the PS4S in that size is £30 less per corner!
The PS4S will be my next tire. But it's a lot of wider than the PZero. The PS4S is like a 245 tire.
So with my 8.5x19, springs and the PS4S it will definitely grind.
No, I mean what i wrote. 235/40 R18, same circumference as 235/35 R19.I think you mean 225/40.
No because the problem won’t be the height. It‘s cause of the width. The PS4S is a big/wide tire and 8.5 is 0.5 more than stock.
Normal driving won’t be affected so much I guess. But on the track or driving the car on it‘s limit it will grind 100% (experience of other guys).
The 18'' look small on this car, imho. I would and will go for 8,5j19R with 245/35 tire. Little more careful on potholes and monitor the pressure so they are 38/35 psiLooks like I will go for the bronze ones in 8x18 ET50 with 235/40 on my shadow grey hatch in spring.
Love the yellow trim on the bumper, much more subtle than the red, any idea where they can be purchased?Bronze looks great on SG, check out this Fastback N:
Makes me want to just get the bronze for my MG and if I don't like it, I can easily paint them next month
Here is another Bronze on an MG:
Don't understand that comment, just measured mine and it's 235mm wide.The Michelin 235 is like a 235 should be and measure. The Pirelli is not more than a 215, really! The difference really is about 20mm.
Stick a tape measure across the tyre, what do you get?This is a 235/35 R19 PS4S on 8x19:
View attachment 10050Can you see the difference in treat-width now? Take a picture of our Pirelli in a similar angle to compare. The Michelin is at each side 7-10mm wider, 15-20 in addition.
