Wheels Motec Ultralight Wheels - Colour options
#46
Great to know, you may have already said it but are you both running 8.5J or should I go for 8? Worried if I get the whiteline springs it may rub with 8.5’s.
c4bl3
#48
The 8x19 are new. Motec started to produce them a few months ago.
If I had the choice I would go for 8x19 for now. With the 8.5x19 on the stock Pirelli PZero you have a lot of stretch cause the PZero has the width of a 215-225 tire. And if you also want to add springs then it's definitely better to go for 8x19.
#49
Cheers, is yours standard ride height? Looks a bit lower than stock, that or the extra width makes them look more flush. 19x8 is probably a good shout then. Plus the PS4S in that size is £30 less per corner!
c4bl3
#50
I have H&R springs. So lowered 35mm.
The PS4S will be my next tire. But it's a lot of wider than the PZero. The PS4S is like a 245 tire.
So with my 8.5x19, springs and the PS4S it will definitely grind.
iiNNEX
#51
My plan was to go with 19x8.5 and PS4S 235/35/19, but only drop the car 20-25mm (whiteline or STA springs).
That should be fine as far as rubbing is concerned right?
c4bl3
#52
No because the problem won’t be the height. It‘s cause of the width. The PS4S is a big/wide tire and 8.5 is 0.5 more than stock.
Normal driving won’t be affected so much I guess. But on the track or driving the car on it‘s limit it will grind 100% (experience of other guys).
#53
I think you mean 225/40.
No, I mean what i wrote. 235/40 R18;), same circumference as 235/35 R19.
Bit „more“ tire to work with. Sadly there‘s no sporty Michelin at that size. PS4 are too sedan-ish. I love the PS2 and PSS for years now, but looks like Goodyear Superport in 235/40.
iiNNEX
#54
So the Michelin is more like a 245 size tyre compared to the P zero, hence that is what is going to get it to rub? Damn, I guess the only option then is to go 10/15mm drop with Eibachs.
Thing is I want the 8.5 wheel because I feel like the 8.0 we have now needs a spacer to look flush.
#56
Looks like I will go for the bronze ones in 8x18 ET50 with 235/40 on my shadow grey hatch in spring.
The 18'' look small on this car, imho. I would and will go for 8,5j19R with 245/35 tire. Little more careful on potholes and monitor the pressure so they are 38/35 psi
