More weird noises
Dimi_dboe
22
30
Florida
Hello, I’ve been a proud VN PP owner for the past 7 months I’ve had no major problems. Maybe some annoyances but nothing crazy.
Today I turned my car on and it’s done this a few times maybe once or twice a week but the I turned the engine on and it seemed to bog down as if not all the cylinders were working very very low RPMs. I could hear it struggling then I heard a high pitched grinding noise as if I was grinding a gear I was in neutral with the clutch all the way to the floor, then it went away. I Turned off the car and turned it back on and it started full force.
I saw something in other forums regarding something to do with the the starter motor or solenoid. I park in a slight incline where my motor is higher and than the gas tank. I thought it had something to do with maybe an underpowered fuel pump.
However, that grinding noise scared me.
Nomad17
317
277
USA
I would think pressing the start button should just be an automated series of events that occurs until the engine fires, and that a quick press should be the same as holding it down, but I occasionally had the same thing you’re describing and since I started holding the start button a full second it has not happened again.
Could be coincidence but worth a shot. I think it may be an injector issue, and this is just a potential bandaid on the problem, but to get the dealer to replicate it is a slim chance and unless you have a great relationship with someone there I don’t think video evidence would do any good.
Dimi_dboe
22
30
Florida
I guess I am going to have to keep recording every cold start because that noise was startling.
thank you for the response buddy :)
