You did a great job and the micro fuse tap option, is freaking outstanding.I installed mine today. I still need more time to appreciate it, but first impressions of the ECS10 built in Comfort and Sport modes (on top of the "stock" Normal mode) are very good. An improvement in my books, less floaty feeling.
Until @R Veloster N gets the english guide, here is some info on how to do the power connection, which is what I found was least clear so far. I decided to use a fuse tap for a clean and removable connection. Our interior fuse panel uses Micro 2 fuses. I got a Micro 2 fuse tap from a local car audio store. I chose a benign accessory to tap into, the interior lamps. This is an unswitched power source, meaning it's powered even when the car is turned off. Since it appears that one must always use the app to activate the ECS10 settings, I do not think being on unswitched power is of any advantage and I will probably change it to a switched source in the future.
The ECS10 power cable has an inline 3A fuse, so any fuse higher than 3A should be ok in the fuse tap for the plug that goes to the ECS10 power line. I bought a 7.5A fuse to connect the ECS10 power cable, but you could use your spare fuse if you like. For the other plug in the fuse tap, which will complete the interior lamp circuit, reuse the 7.5A that was removed to plug in the fuse tap. Note the orientation of the fuse tap and the 7.5A fuse when you remove it. The passenger side contact is the hot side, so the fuse tap should go in with the output wire (with the blue crimp connector on my fuse tap) pointing to the driver side.
Install the fuses into the fuse tap in the same orientation as the 7.5A fuse was in the interior lamp plug. In the Paint schematic in the image below, yellow is the fuse for my ECS10 power and green is the original interior lamp 7.5A fuse. Strip the end of the flying lead of the ECS10 power cable and fasten it in the crimp fitting of the fuse tap (blue).
For the ground lug, I used the stud at the bottom of the fuse panel. Release the nut (1 in image below) using a 10mm wrench enough to be able to slip the ground lug of the ECS10 power cable around the stud and between the plastic bracket of the fuse panel and the metal bracket (2). Before connection to the ECS10, make sure you have a good connection from the ECS10 power plug connector (the black wire contact) to the backside of the metal bracket using a multimeter.
No you don't really!Sounds like a big month, happy to hear the kidney stone turned out ok in the end...I don't want to imagine what that's like![]()
