Lost tool tip behind the dashboard
HeatzZ
16
11
So today i tried to swap out the tweeters in the car. Unfortunately my stupid ass lost a tool tipp in the tweeter hole. I‘ve been tryingto find the lost tool tip in the dashboard for the past few hours but no luck there.
Anyone got an idea what the best way would be to get the lost tool tip out of the dashboard?
Thanks in advance for your help!
Reactions: Mikemr305
J BOB
336
406
wigan
If it rattles about it will distroy the ownership pleasure, if not buy a new tool and forget about it, not worth stripping the dash out, had an E.C.U replaced on a previous car and I'm convinced a 'TECHNICIAN' lost a screwdriver or something, got rid soon later!
Mikemr305
347
332
Miami
Reminds me of the nightmare when i lost a downpipe stud nut and spent 2 hours with a magnet trying to find it 😪
Tom Vanlimbergen
450
543
46
Buy yourself a camera to look in cavities. Resembles the yools above but then with an extra cameratip so you can see what you're doing.
Comes in very handy and doesn't cost that much (about 50 euro).
3,471
Inexpensive and actually work quite well
if you want better quality;
Dj_Nick
55
33
Madrid
www.djnick.es
For your security, if was on the tweeter over fuse box side, check it out.
I had a similar issue with a bits extension on my first Megane II, and it went to fall onto the back of the fuse box, blowing various of them.
  • Wow
Jacool
Poland
If its passanger side then it is quite easy to remove the glove box and maybe You'll have better access from the underside of the dashboard to find and reach the lost tool. There are crash bar, passanger airbag and air tunnels leading to the side vents underside and since tweeters are near the firewall i dont remember if You'll be able to reach that far. Worth a try considering its a half an hour job though. Good luck
HeatzZ
16
11
already tried that but no luck there as there is no way to reach the top from behind the glove box :(
Thanks though!
